trany swaps
Old Apr 6, 2013 | 10:55 AM
thecaptain's Avatar
Default trany swaps
Hi got a a 90 7.3, good strong motor with only 130k on it. It has a e40d in it now but I would like to stuff a 4-5 speed manual in it, having trouble finding a donor. Was wondering if the 460 gasser trany would bolt up or is there an adapter that I would need, or if there is any other manuel that would bolt up without a bunch of spendy adapters.
I realize that its a total pain to swap from automagic to manual, however the reliability of a manual is more important to me then babying the auto.
In reality an older granny low trany would be ideal, say from a 70's furd, I don't spend much time on the freeway, its a rare day that I can go over 60mph... the truck will do it, just not while driving over the people in front of me.
Old Apr 6, 2013 | 01:52 PM
FordDZLMan9191's Avatar
I'm not sure whats needed to swap in a NP435(70s Ford) but I know it can be done. A T-19 4 speed from a 83-86 6.9 would be a bolt in deal. You can use the transfer case you have already(if 4x4) and don't have to change driveshaft length. A 460 gasser trans would need holes drilled in the correct locations on the bell housing to work.
Sent with the hammer down and grabbin' gears via Tapatalk.
Old Apr 6, 2013 | 03:09 PM
thecaptain's Avatar
Well then, if its just a few holes, that's no problem at all, Machinist by day. As long as the big ugly starter lines up and the cross member fits, sounds like a plan, drive lines can be cut stretched and skewed fairly cheap near by.
Old Apr 6, 2013 | 04:11 PM
Double check a 460 4 speed if that's the route you're going. I know on a 460 ZF5 new holes need drilled. There's at least one good thread on here about swapping from an auto to manual, so you might try a search for more info.
Nov 28, 2014 09:50 PM
