2004 F250 6.0 fueling system
Old Apr 5, 2013 | 06:24 PM
davisa26's Avatar
Default 2004 F250 6.0 fueling system
I have a 2004 f250 6.0 diesel with 170,000 miles and still has original pump as far I know. my truck sputtered 5-6 times while idling, I then switched it off and later on 10-15 minutes it wouldn't crank. Could this be a fuel pump problem? And also where is the fuel pump located? Is it part of the fuel filter assembly under the driver door? Also when the frame mounted filter isoff and you turn the key should it pump fuel out of the housing?
Old Apr 5, 2013 | 11:05 PM
bobfbigman's Avatar
I don't think it will pump with filter and cap off, yes the fuel pump sits in the same housing as the frame mounted filter, it is on the front of the housing.
Old Apr 6, 2013 | 08:46 AM
davisa26's Avatar
Would fuel pump up in the motor mounted top filter with the cap and filter off?
On the front filter it filled immediately when turn key on and held the pressure after key was switched off, no leak down at all. I guess that rules out my fuel pump so on to more trouble shooting
Old Apr 6, 2013 | 02:43 PM
bobfbigman's Avatar
does your oil pressure guage go up when cranking? it might take several seconds for it to move. if yes then you low pressure pump is good, I am thinking its the high pressure pump but a good scan would tell you for sure.
Old Apr 6, 2013 | 03:38 PM
davisa26's Avatar
Yes the oil pressure is good while cranking! What symptoms would the high pressure have?
Old Apr 6, 2013 | 03:49 PM
bobfbigman's Avatar
crank but no start.
to start you need:
1: Ficm firing, hear injectors buzz?
2: air, basically make sure turbo is not siezed
3: High Pressure oil, need 500psi to operate injectors
4: fuel, fuel pressure should be around 60+psi but it will start with less, damage to injectors below 50psi
Old Apr 6, 2013 | 03:52 PM
davisa26's Avatar
I got the truck to crank and there was a loud knocking sound and the belt was jumping and the alternator pulley was moving up and down probably close to an inch, I switched the truck off and could smell something burning, tried recranking but wouldn't crank and run just tried to crank.
JaysTruck
Jul 22, 2015 11:49 AM
Jakem96
Apr 5, 2015 12:34 PM
mrfizz2012
Dec 11, 2014 10:38 PM
totalchaos
Oct 18, 2014 08:46 PM
