Down Pipe
Old Apr 5, 2013 | 10:49 AM
bigrig73's Avatar
Default Down Pipe
What's the best way to pull a down pipe off of a 6.7L cummins. I'm going to put a 5" staright pipe on mine.
Old Apr 5, 2013 | 02:54 PM
jdinny's Avatar
remove the trans mount bolts, jack up the trans, loosen and remove the cross member bolts, you can leave one in the drivers side, and just swing the cross member down on the passenger side.
Remove bolts from the pipe support, and the v band clamp where the pipe bolts to the back of the turbo
Old Apr 6, 2013 | 08:39 PM
cummins05's Avatar
^^^^^ what he said!! Was the hardest part of my whole delete process!
Old Apr 6, 2013 | 10:44 PM
coors_man_2005's Avatar
about 5 mins and a torch a saw is ok but better have a lot of blades that stuff is tuff right there its not your normal exhaust pipe
Old Apr 7, 2013 | 08:05 AM
jdinny's Avatar
yup, and then when our wonderful EPA makes us put 'em back on, you gotta buy one.
No thanks
Old Apr 7, 2013 | 08:45 AM
so dont deal with the epa. know your ways around it or leave it stock. theres ways around everything. my truck will never run emissions again. worst come to worse my truck will wind up being an 07 5.9 on the title and vin numbers anyway.
Old Apr 7, 2013 | 08:47 AM
jdinny's Avatar
good for you
Old Apr 7, 2013 | 09:33 AM
cummins05's Avatar
Still have to move that cross piece so u can get the new one in. Or i did at least!
Old Apr 7, 2013 | 09:46 AM
jdinny's Avatar
AFE used to make a two piece downpipe, not sure if they still do.
You could get that one in if you wanted to cut your original out
Old Apr 7, 2013 | 11:14 PM
my 5'' went right in no problems.
