crank sensor?
Old Apr 4, 2013 | 10:43 PM
willis964x4's Avatar
Default crank sensor?
What are the symptoms of a bad or going bad crank sensor? Where on the truck is the crank sensor located?___
Old Apr 5, 2013 | 04:56 AM
97cummins's Avatar
On some vehicles the crank sensor can control the shift points of the transmission, Timing,ect.
On alot of vehicles the sensor can be found right on top of the vibration dampner.
Old Apr 5, 2013 | 06:34 AM
West MI Mudder's Avatar
Are you talking about the crankshaft position sensor? If so, it located right around the power steering resovoir i do believe. A bad CPS can cause a few diferent things. On some trucks, it wont even let it start. It can also make it run as if the injectors are stuck open
Sent from my LG-P506 using Tapatalk 2
Old Apr 7, 2013 | 06:50 PM
racer55's Avatar
Check for codes first.
Also only replace with AC Delco the BWD's are often junk out of the box.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Dyesel67
Jun 23, 2015 01:30 AM
Mr. Walkway
May 11, 2015 10:49 AM
robbyS
Apr 16, 2015 02:22 PM
