92 cummins auto won't hold 100 km/hr
Old Apr 4, 2013 | 08:28 PM
1stgencumminsdenis's Avatar
Default 92 cummins auto won't hold 100 km/hr
My truck is stock except the full power screw is turned up a full turn, i have the 3 speed auto with overdrive and i have roughly 300,000 kms on it and from as far as i can tell i dont have a boost leak , could someone please help me with my first truck? I just wanna hold 100 on a hill from what my dad says these trucks have tremendous power but so far i cant see it , any help as to what might be wrong?
Old Apr 4, 2013 | 09:28 PM
92betsy's Avatar
Is your high idle screw removed? That will help, a 3200gov spring will help to. Mine even up hill will hold speed no problem, with minimal peddle adjustment. I can do over 100mph or 160km/h for you Canadian folk. That's with just a fuel pin, turned up pump, high idle screw MIA, and 3200 spring. A timing bump will help with the top end power also.
Old Apr 5, 2013 | 12:02 AM
Whats does the high idle screw have to do with keeping a hundred kn a hill? Where is it located?
Old Apr 5, 2013 | 09:04 AM
92betsy's Avatar
It will give you more rev, move your throttle open by hand the screw it hits on the head of the front of the pump remove it. You want the throttle to be able to hit the head of the pump at WOT. Plus if it is in to far it will limit what fueling you have. Are you just out of throttle, or are you just low on power? Do you have gauges[egt, boost, fuel psi]? If so how much boost are you pushing up the hill, and what's your pyro say? If your out of power going up hill then you may have something wrong with your truck. Mines the same year and trans as yours, and at stock power with nothing wrong I would have to be going up a very steep hill not to keep the speed limit with just pushing the peddle in a little more. With it turned up it makes it even easier. Do you know what you fuel pressure is? If your not getting fuel your not getting power.
Old Apr 5, 2013 | 03:01 PM
I have no gauges not even a tach, i dont run out of pedal but i have to continuosly press the throttle in farther to hold speed
Im really at a loss right now i wish i knew why my truck is lacking power so much and im not sire what you mean by removing tge screw at the front of the pump?
Last edited by 1stgencumminsdenis; Apr 5, 2013 at 03:01 PM. Reason: Automerged Doublepost
metrickjb
Jan 21, 2015 04:16 AM
Dec 18, 2014 03:25 AM
1ATony
1A Auto Parts
Dec 1, 2014 09:34 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
