Newish owner of a 7.3 any ideas or concerns
Old Apr 4, 2013 | 07:30 AM
hookpowerstroke's Avatar
Default Newish owner of a 7.3 any ideas or concerns
I bought my 7.3 finally after bout searching for 6 years and i was wondering what i can do or need to look out for with my truck. I bought it with only 82k miles now its just under 100k and ive already done exhaust with downpipe, cold air (k&n), and a TS performance 6 position chip. I know i need to replace the injectors,switch valve covers, head studs, and i want to put a wicked wheel in my turbo plus convert to a ZF-5 speed...any ideas are appriciated.
Old Apr 4, 2013 | 01:54 PM
usaman's Avatar
Congrats on the OBS! W/ such low milage there isnt a concern to replace the sticks unless of course speed is the answer and that would follow w/ the studs, which only need replacing if you intend to shoot for 500hp+. The turbo wheel wont make a difference but you should inspect it for wear on the fins. Bends and chips, not good and with the KN filter that probably will be seen..Deep six it cause they leak and lets tons of dirt in. Not sure why you would need to replace the VC's but you could upgrade the HPOP which you would need to do w/ stage 2's.
Old Apr 4, 2013 | 05:59 PM
I wish i new more bout my obs becuz its my first diesel but i dont just trying to figure stuff out with it and thanks for the advice ill def look into gettin everything checked out...what should i do for a filter ive heard a few different ones skimmin the forums and talkin to ppl i just got that one cuz i didnt have to order it...as far as HPOP what would i need that for? Im feel dumb becuz i dont know anything about diesels but now i own one and cant do any work myself
Old Apr 5, 2013 | 06:15 AM
autostroker's Avatar
Go to NAPA and get a filter, i think the number is 4366, but cant remember for sure, somone please chime in if im wrong. but its easy to install and does a great job. have a pic of mine in my gallary if you want to see. just need to take out filter box and get a chunk of 4 inch tube with a 45 degree bend in it to hook it up. Cheap filter and works great.
Old Apr 5, 2013 | 08:41 AM
Thanks guys i appreciate the help
Old Apr 5, 2013 | 05:59 PM
POWER-STRUCK's Avatar
wix# 46637 or napa# 6637
Old Apr 8, 2013 | 06:17 AM
thanks for the right filter numbers, i couldent remember it off the top of my head.
Old Apr 9, 2013 | 07:48 PM
usaman's Avatar
your filter: Riffraff Diesel: RDP 6637 Filter Kit (Out of Stock) Clay at riffraff diesel is the man: nice toys and he wont steer ya wrong.
Your stock hpop wont be able to supply the necessay pressure for the new and improved sitcks you want to install...you will need higher and more consistent high pressure oil feeding the high performance injector sticks you're looking to install. Most guys go for the T500 ( terminator) or the Adrenaline brand. The wild bunch go for dual HPOP's. now your cooking....
Old Apr 12, 2013 | 04:03 PM
afau's Avatar
you can also use a baldwin filter dont remember the number right now, i used the same original tube junt took out the box and its done it hauls and whistles
UniqueCopy
Dec 14, 2014 11:37 AM
