hard starting??
Old Apr 3, 2013 | 08:38 PM
hulse09's Avatar
Default hard starting??
so i just rebilt my motor. well befor i went a rebuilt it i had probablems starting. i would hv to let the lift pump run 3 times or more in order for it to start. now that i rebult the motor i still have the some probablem i know when i took the motor out the return line on the back of the head was a lil lose but i made sure it was tight when i put it back in. i dont notice and fuel leaking anywhere so im stumped. i have a raptor 150 on my truck. what should i be running for fuel pressure. should the LP run when cranking the motor over? if so mine isint. need to get this figured out its driving me nuts!!!
Old Apr 4, 2013 | 12:15 AM
RanchhandTCR's Avatar
I know if you have to much pressure it creates a hard start, fuel pressure should not be more than 22-24 PSI. If its more turn it down. The lift pump will kick on if you dont have a succesfull start. IF it not that, nore fuel filters, then possibly the injection pump.
Old Apr 4, 2013 | 08:27 AM
SRTcummins's Avatar
Wait what did you rebuild exactly?
Old Apr 4, 2013 | 04:28 PM
hulse09's Avatar
the whole motor. piston barings injectors new cam turbo manifold studded the head on o ring. 115# springs. im going to try a lower my fuel presure to 16?? see if that helps
Old Apr 4, 2013 | 10:00 PM
Buzzin half dozen's Avatar
16-18 pounds should be about right just keep it under 20. Yes the lp should be running while cranking if its not that could be part of the problem. How does it run once it starts?
Old Apr 4, 2013 | 10:38 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i have had to wire fass pumps where they didnt pump while cranking.
Old Apr 5, 2013 | 11:32 AM
SRTcummins's Avatar
Did you rebuild it because of the hardstarting? Or just because of performance.
Old Apr 5, 2013 | 09:32 PM
hulse09's Avatar
performance. so should the LP run while cranking?? i adj the press to 17 17.5 and still hard start. runs fine after it starts but i have to run the lp 2-3 times befor it will start
Old Apr 6, 2013 | 01:25 AM
BBD Tech Support's Avatar
The Factory LP runs 25-30 sec at first turn of key and should also run while you'er starting the engine.
Old Apr 6, 2013 | 12:14 PM
hulse09's Avatar
is there a way i can get my raptor 150 to run while cranking? like put a switch on it?
