6.9 Fuel Tank Building Extreme Pressure
Old Mar 29, 2013 | 05:59 PM
TwinSpooled's Avatar
Question 6.9 Fuel Tank Building Extreme Pressure
I have an 87 6.9L IDI. New injestion pump, fuel pump, and fuel filter. The fuel tank is building ALOT of pressure. When I remove the fuel cap (new) it sounds like your opening a shook up 2 liter of Coke, fuel gurgles up and out the filler neck, and white vapor. Also, it will idle forever but dies after driving it an 1/8 or 1/4 mile.
1. Has anyone had or seen this problem before?
2. How did you fix it?
3. Are they related?
Thank you.
Old Apr 1, 2013 | 01:52 PM
dieselgirl86's Avatar
Possible of a blockage in the fuel line
Old Apr 1, 2013 | 02:24 PM
I figured out the 2 problems are related. Whatever is causing the tank to build pressure is causing the truck to die. The IP shuts down at 7+ PSI to keep from blowing any seals. So when the tank builds enough pressure the IP shuts down. But I am still unable to find out why the tank is being pressurised. If I back the fuel cap off a quarter turn or just enough to brake the seal of the cap on the filler neck it runs as long as you want it to.
Old Apr 2, 2013 | 06:24 AM
autostroker's Avatar
need a new fuel cap with a good vent in it, sounds like vent is plugged on yours.
Old Apr 2, 2013 | 07:07 PM
Truck already has new fuel cap. New IP. New filter. New pump. New glow plugs. New injectors. Its not just building a little bit if pressure. Its almost like the IP or fuel pump is pressurising it. is that possible?
Old Apr 3, 2013 | 06:24 AM
I dont know how it would unless you are sucking in a bunch of air with the fuel pump, in which case, truck would not run verywell.
Old Apr 3, 2013 | 04:35 PM
Its runs great if I keep the fuel cap loose.
Actually in runs great with it tightened down for a minute or two then the tank builds enough pressure to shut the IP down.
Last edited by TwinSpooled; Apr 3, 2013 at 04:35 PM. Reason: Automerged Doublepost
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
