abs light not showing up when key is switched on?
Old Mar 28, 2013 | 07:51 PM
jrr3006's Avatar
Default abs light not showing up when key is switched on?
I have a 99 dodge I need title rebuilt which means a state inspector must come and check it out, which one of the things he's going to check is if the abs and air bag light comes on for3 to 5 sec what's wrong if it doesn't come on?
Old Mar 28, 2013 | 07:55 PM
RAW's Avatar
RAW
Could just be a bulb burnt out. It isn't too tricky to pull the gauge cluster out and access the bulbs. Swap the ABS bulb out with a known good bulb (signal, hi beam indicator, etc) reinstall and try again. You may be able to visually inspect the bulb for a burnt element as well.
Old Mar 28, 2013 | 08:07 PM
jrr3006's Avatar
How often do they go out
Old Mar 29, 2013 | 12:48 AM
superjoe83's Avatar
im not sure about a '99 cluster, but my '01 uses bulbs just for the back lighting and turn indicators, all of the warning lamps are backlit by non serviceable LED's, first i would check all fuses for the ABS and airbag and go from there
Radioking1777
Jun 9, 2015 04:13 AM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
yams
Dec 7, 2014 12:51 PM
ValleyF250
Nov 1, 2014 07:56 PM
