Truck won't start
Old Mar 27, 2013 | 03:27 PM
Cow tipper's Avatar
Default Truck won't start
I have a 93 cummins and I shut it off and when I tried turning it back on it wouldn't start. So I had my friend give me a jump and it started right up and then a minute later it just shuts off. I have no power to anything and I just replaced the battery in it. So could this be a bad alternator or lift pump or even a fuel pump? I'm stuck. Thanks for any advice
Old Mar 31, 2013 | 09:47 PM
Cow tipper's Avatar
or not
Old Mar 31, 2013 | 10:44 PM
BBD Tech Support's Avatar
Make sure you are getting 12v to the Cutoff solenoid on the Injection pump With the key on (0v with key off)
Old Apr 1, 2013 | 08:31 PM
UCTJ's Avatar
Yes check to make sure you are getting power to your Fuel Shutoff Solenoid. Mine has been acting silly like that lately, basically I'll go to start it up and normally one bump of they key boom its started. But if I loose good ground to the FSS it'll just crank.
Old Apr 2, 2013 | 09:48 PM
Screamin' Metal's Avatar
If your battery is discharging, would cause this, also the fss. If it starts and then it dies, with your loosing voltage, Could be the IP, could be a bunch of things. Check the FSS 1st. Hows the Fuel filter?
Old Apr 14, 2013 | 12:13 PM
Cow tipper's Avatar
the fuel filter is fine as far as I know. Its my friends truck so im just trying to help him out. and ill have to check the fss. Thanks guys
Old Apr 15, 2013 | 09:32 AM
dodgeramit10's Avatar
check your voltage regulator...... that would be my first guess. those things dont last too long anyway.
Old Apr 15, 2013 | 01:49 PM
Yep! And always carry a spare regulator, a roll of wire, some electrical tape, bailing wire, a small tool kit and your set to run coast to coast!
doublehbar
13
Aug 9, 2015 12:35 AM
doublehbar
33
Jun 5, 2015 11:38 AM
dfish001
Mar 30, 2015 03:07 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
ronstop
Feb 26, 2015 09:48 AM
