5th Gear Nut??
Old Mar 27, 2013 | 08:35 AM
colinheitshusen's Avatar
Default 5th Gear Nut??
Driving my bosses 99 24 5 speed this morning and was coming up to a stop light. all of a sudden i couldnt pull it out of 5th. finally jerked it out and couldnt get it into any gear. its stuck in nuetral and and wont slide over to 5th and reverse, and will slide between 1st-4th but will not go into any gears. If you have the stick in nuetral and release the clutch it will move forward as though its stuck in 4th or 5th. Is this a case of losing the 5th gear nut? or did i bust the linkage?
Anything helps, thanks
Colin
Old Mar 27, 2013 | 09:42 AM
MillerBoyzDiesel's Avatar
sounds like linkage prob.
Old Mar 27, 2013 | 10:09 AM
RAW's Avatar
RAW
Yep, sounds like linkage. It isn't to tricky to get access to it. Remove the shifter boot, then you will see where the shifter attaches to the trans. Remove that, and have a look at the shift rods.
Old Mar 28, 2013 | 09:32 AM
Well it sounds like a fork or the top plate is busted. Sounds like the boss is just going to replace the whole trans seeing as that 3rd and 4th synchros are out.
I feel pretty unlucky seeing as that its the 2nd dodge trans ive killed in a month.
corksil
Aug 2, 2015 10:19 PM
Jun 4, 2015 09:30 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:27 AM
rtbcoop
Nov 29, 2014 11:33 PM
miked2805
Oct 29, 2014 06:20 PM
