ticking noise on 04 cummins normal?
hey guys
Im new here so i hope iam posting in the rite place, but i have an 04 cummins i just recently bought and i am hearing a slight ticking noise comeing from the engine at idle and only once the truck warms up to normal running temp.
I am curious about a few things, first is this normal for these trucks?
Second if it is not normal what could it be?
thanks in advance guys.
Check your injector line hold down bolts, the small 8mm bolts can loosen over time especially #4. Also could be an injector. If you have access to a scan tool you can shut off the injectors one at a time and see if the ticking goes away once the injector is shut off.
yea good advice the hold down clamps were first on my list to check and they were all tight
if it were a bad injector i would think it would white smoke idle rough or get bad milage and the truck is getting around 20 all around and 23 if i baby it
Last edited by 5.9inline2008; Mar 26, 2013 at 09:46 AM. Reason: Automerged Doublepost
might smoke some very light haze possibly but might not smoke all the time or at all. If the tick doesnt go away when you shut off the injectors you can start checking your valve train. Valve lash, rocker arm pivot shafts.
chootem
Jul 18, 2015 08:29 PM
mr. dune-a-holic
May 4, 2015 01:39 PM
btg2820
Apr 27, 2015 12:09 AM
Boatman
Mar 20, 2015 10:00 AM
Oct 24, 2014 04:40 AM
