turbo upgrade
Old Mar 25, 2013 | 07:52 PM
cmtoutlaw34's Avatar
Default turbo upgrade
hello im new to the diesel game i have got me a 1996 chevy 1500 6.5 turbo diesel 4x4 run awesome just rolled it over 271000 miles and runs like a brand new truck the only problem i have is my wastegate is not working like its suppose to i have it tied open right now till i have time to go order a new one im also looking at upgrading to the HX40W-II turbo with the dimond eye 5 inch stright pipe muffler delete from turbo back with a upgraded wastegate would i need to do anything to make that turbo work or would it just be easier to put the upgraded exhaust and keep the stock turbo and just get a new wastegate
Old Mar 25, 2013 | 08:35 PM
Mase's Avatar
Post in 6.2 and 6.5 forum.You will get some answers.
Old Mar 26, 2013 | 11:50 AM
racer55's Avatar
You need to do some diagnosis on your end.
The wastegate is vacuum controlled by the ECM-tying it shut is a bad move.
A turbomaster from Heath Diesel or repairing the factory vac system needs done to retain the factory turbo.
An HX 40 is a godo replacement choice but needs some fab work done to make it fit.
Do you have any trouble codes?
Does your vac pump work?
Are the plastic vac lines cracked,broken or leaking?
Is the electrical harness intact at the wastegate solenoid?
Is the diaphragm intact in the wastegate actuator?
Do you have a S or F vin for the 8th digit of the VIN?
Old Mar 26, 2013 | 02:28 PM
no i dont have any trouble codes other than the abs light on
the plastic vac line has no leaks and is hooked up as it should be
how can i tell if my vac pump is
all the electrical lines lines leading to the wastegate solenoid are intact and hooked up
the diaphragm in the wastegate is intact cause at a hard throttle it will draw maybe 1-3 psi of boost.
and the 8th letter in the vin is a s
Old Mar 26, 2013 | 02:58 PM
racer55's Avatar
help help help - Diesel Place : Chevrolet and GMC Diesel Truck Forums
You need to get a vacuum gauge and check for vacuum at all locations to troubleshoot where it is being blocked/lost.
From the vac pump should be 24" +
At the wastegate actuator should be 18"+
Cdog121
Nov 16, 2015 01:49 PM
n2brk
Feb 21, 2015 09:05 AM
BIGRED12V
16
Jan 3, 2015 07:47 PM
brown2294
Nov 3, 2014 10:09 PM
strokin97
Sep 30, 2014 11:59 PM
