Blackwater Engine
Old Mar 25, 2013 | 12:12 AM
blownchevy's Avatar
Default Blackwater Engine
i Just installed a remanufactured 6.0 long block from Blackwater with fully Bullet Proof kit. All was well until i was letting it idle to warm up the head gasket on the left side started to leak. Has any1 had any dealings with these peeps, the gasket appears to be stock from the tab i see. Do the black Onixs gaskets look like stock ones?
Old Mar 25, 2013 | 08:38 AM
MillerBoyzDiesel's Avatar
Black onyx are black all over. The last shop I worked at used black water or j and k and they were coming with the onyx gaskets and claimed they never had any problems out of them. Id call them because you should have a warranty.
Old Mar 25, 2013 | 02:16 PM
blownchevy's Avatar
Thanks will do, these must be OEM. The leak only happens when the engine is running, i pressurized the cooling system to 16psi no leak until i fired it up. I hope is was a torquing issue and not a machining one.
Old Apr 8, 2013 | 01:28 PM
rowekmr's Avatar
Any updates?
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
hershwork
Mar 1, 2015 05:15 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
hunt4beer
Nov 15, 2014 09:06 AM
