Code 2149
Old Mar 24, 2013 | 06:48 PM
Hammerheadsh's Avatar
Default Code 2149
My truck just blew another injector.last time it was the number injector.now I just threw code 2149 which is either number 4,5 or 6.if it 5 or 6 how do u get the injectors out.they will hit the top of the firewall.is it common to start losing injectors at 135,000 miles.i have the edge hot juice but only run on the 3rd setting and a bully dog crazy Larry downloaded that I keep on tow mode.and I have an industrial injection 62/12 turbo.any help will be appreciated .
Old Mar 25, 2013 | 12:34 AM
CHEMMINS's Avatar
Iirc the Juice and the BD both do pressures. That is probably why you are blowing your injectors.
Old Mar 25, 2013 | 11:09 AM
I thought the bully dog changed the timing. Is there a good shop I can talk too
Old Mar 25, 2013 | 04:18 PM
CHEMMINS's Avatar
Depending on the version of the CL you are adding pressure, duration, and timing.
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
