6.5 need help asap
Old Mar 23, 2013 | 04:01 PM
kylek's Avatar
Default 6.5 need help asap
ok so i have a chevy 2500 6.5 td not getting fuel to the t valve if its running. if i turn the truck off and pull the pump relay out and hook a jumper to it i get fuel coming out good flow but if start the truck with the jumper on still no fuel whats going on im at a lost for ideas need help asap because my truck if my money maker
Old Mar 23, 2013 | 04:10 PM
Mase's Avatar
I'm still learning myself but it sounds like a lift pump issue.Does it still run and if so does it run as good as it always did.
Old Mar 23, 2013 | 04:17 PM
kylek's Avatar
its not the lift pump i replaced that already.
Old Mar 23, 2013 | 04:28 PM
Mase's Avatar
Maybe you will get lucky and Mayhem or racer55 will chime in here because that is odd?
Old Mar 23, 2013 | 05:18 PM
Mayhem's Avatar
What kind of LP did you put in the truck ??what brand???
Old Mar 23, 2013 | 05:32 PM
kylek's Avatar
Ac delco and I have on from ssdiesel supply truck has New ops ac delco
Old Mar 23, 2013 | 06:38 PM
Mayhem's Avatar
Is your truck OBDI or OBDII??
Old Mar 23, 2013 | 10:20 PM
kylek's Avatar
obdI ITS A 95
Old Mar 23, 2013 | 11:12 PM
Mayhem's Avatar
You might want to do the OPS mod located here
OPS relay install - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Old Mar 24, 2013 | 11:26 AM
racer55's Avatar
Check for power on the orange wire in the OPS harness.
If power there jump the orange and grey wire to confirm the circuit is ok-it should run the LP.
If not diagnose the break in the grey wire.
