afc/manifold issue
Old Mar 22, 2013 | 01:08 PM
peterbuilt1024's Avatar
Default afc/manifold issue
Hello I have a 92 5.9 12 valve. I am trying to figure out if i have a boost problem. I have boost/air out of the turbo into the inner cooler and out of the inner cooler and into the intake. From there i am unsure where the air goes or what it does but i do know i have very little air going into the afc housing out of the afc line the comes out of the manifold.
Old Mar 26, 2013 | 02:33 PM
36Valved I6s's Avatar
whats the issue? Air then goes into the cylinders as allowed by the cam....air also is directed into the afc to via that boost line to it pushing down on the fuel pin/diaphragm allowing more fueling
Old Apr 1, 2013 | 06:46 AM
I don't have enough air going into the afc housing.
Old Apr 1, 2013 | 05:47 PM
BC847's Avatar
At idle, you'll have very little, if any air coming out of the AFC's reference tube.
As the boost comes up, that tube carries the boost pressure to the AFC diaphragm. As the pressure goes up, the diaphragm moves against the AFC spring and allows increased fueling to match the boost.
Old Apr 1, 2013 | 06:04 PM
BBD Tech Support's Avatar
How have you measured the PSI you are getting to the AFC?
Old Apr 1, 2013 | 06:20 PM
BC847's Avatar
Git'cher fresh strawberry's at Homey's Heat'in Air & Produce.
(My original post was redundant and I can't delete this post).
Old Apr 9, 2013 | 09:38 AM
I am getting no air what so ever in the afc line going to the afc housing. any idea why?
Old Apr 9, 2013 | 07:39 PM
DMan1198's Avatar
Some kind of blockage in the line perhaps or the line has been squished somewhere
Diesel_Daddy6.0
Nov 12, 2015 09:33 PM
Diesel_Daddy6.0
Sep 23, 2015 03:12 AM
dskewes14
Sep 14, 2015 09:19 AM
JKinni
13
Sep 5, 2015 11:09 PM
Oct 23, 2014 08:10 AM
