Turbo issue
Old Mar 21, 2013 | 10:08 AM
spark68's Avatar
Default Turbo issue
Just got done with head job and alls well with the exception of turbo/boost. Throws a code for turbo/supercharger circuit low. when I key on the turbo gauge goes to 0 level but then drops out like it lost all contact. Being theres only one connection to turbo which is the VGT is there a test for the VGT functiong correctly? Take it up to abot 2500 RPM and the programmer (Edge) shows only 3-7 lbs.
Old Mar 21, 2013 | 10:14 AM
MillerBoyzDiesel's Avatar
you can go in with a scan tool and change vgt vane percentages with a boost gauge installed and see what you readings you get.
Old Mar 21, 2013 | 10:19 AM
spark68's Avatar
Default Turbo
What should the readings be? say at 2000, 2500,3000 RPM
Old Mar 21, 2013 | 10:21 AM
I cant remember off hand, if you have the code I can look it up.
Old Mar 21, 2013 | 11:02 AM
spark68's Avatar
Default turbo
Well new development got my dumass out there and hooke in the intake air lin to the sensor by the heater/ac box. I had taken it off to make room for the head removal and I ddint put it back in yet. Both gauge on instrument and programmer read now but no power like it ought to. Sounded like a pretty good leak in one of the pipes so get that dialed in and see what happens.
avatardvr
18
Aug 8, 2019 12:38 AM
sak240
Oct 1, 2015 04:07 PM
bigblu
18
May 10, 2015 10:52 AM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
