6.9 idi wont start
Old Mar 21, 2013 | 08:37 AM
Troy6.9's Avatar
Default 6.9 idi wont start
Hi. I have a 6.9 idi that wont start. The truck will run on starting fluid but not of diesel. I put new return lines on it an new o rings around injectors. I also put new fuel filter on it and new diesel it the tank. When the truck turns over their is white smoke coming from exhaust. I bled all the injector line several times too. i dont know what else to do to get this truck running. Is their a solenoid that could be bad or am i just not doing something right . Please help!!!
Old Mar 22, 2013 | 03:58 AM
97cummins's Avatar
Is your lift pump working?If you put this in the ford 7.3 section you'll get a better responce.This is the introduce yourself section.
Old Mar 22, 2013 | 03:41 PM
1ATony's Avatar
Welcome to the site
Old Mar 29, 2013 | 01:42 AM
dieselgirl86's Avatar
Maybe is your fuel pump
Old Mar 31, 2013 | 11:30 PM
Troy6.9's Avatar
Injection pump is new. I didnt put it in so how do u tell if it is in time? Or could it be the power supply? Thanks every one for helpin me out on this
Old Apr 1, 2013 | 01:40 PM
Also check to see if you glow plugs are new. The cylinder may not get hot enough to ignite the fuel in the cylinder
Old Apr 2, 2013 | 08:08 AM
Troy6.9's Avatar
How do you test the glow plugs?
Old Apr 2, 2013 | 06:54 PM
This is what I found out http://www.ehow.com/how_6504958_glow...iesel-bad.html
Old Apr 3, 2013 | 09:30 PM
Troy6.9's Avatar
Thank you i will try that next!
Old Apr 3, 2013 | 10:29 PM
Tell me how that go
