trans prob 98.5 cummins 47re trans
Old Mar 21, 2013 | 12:39 AM
scout one's Avatar
Default trans prob 98.5 cummins 47re trans
sometimes when i back up and shift to drive and take off it wo,nt shift out of low, any ideas thanks scoutone p.s. also new here.
Old Mar 21, 2013 | 06:29 AM
SRTcummins's Avatar
What do you mean "shift out of low"
Old Mar 21, 2013 | 07:13 AM
RAW's Avatar
RAW
It won't come out of first gear after being in reverse?
Old Mar 21, 2013 | 09:53 AM
scout one's Avatar
yes it won,t up shift stays in 1st gear, i park it overnite and its ok the next day. thanks for replie
Old Mar 21, 2013 | 10:49 AM
SRTcummins's Avatar
Check your TV cable(throttle valve) it controls something to do with shifting mine gets stuck and won't let my trans shift sometimes
Old Mar 21, 2013 | 12:02 PM
RAW's Avatar
RAW
Scanned it for codes?
Old Mar 21, 2013 | 06:06 PM
scout one's Avatar
yes scaned for codes, none will check tv cable thanks for info. thought about getting a new truck. but i really like this truck. it has about 210,000 miles on it and the only repairs have been a alt. lift pump, brakes, shocks, reg. maintence, and a seat belt relay. oh and a crank sensor. thanks will let you know if i find prob.
Old Mar 21, 2013 | 08:13 PM
RAW's Avatar
RAW
Getting a new one just because of a shifting issue sounds silly to me. If you need a whole trans job after figuring it out, different story. A have a buddy, well...maybe not much of one anymore, who sold his truck and bought a new one because of an external coolant leak from his head gasket. Same guy that wouldn't shut up about how much he loves his truck. He is a mechanic to make the story more sad!
Speedometer works? If you have a pal with a scanner, watch gov pressure and see what it is like. Could just be a sensor, or solenoid.
Old Aug 19, 2013 | 07:30 AM
Bigoldjeep's Avatar
My 47RE will duplicate this issue as well. When the trans is any warmer than 140F and after I reverse with any throttle abpve idle, the next forward drive the trans will stay in 1st. To work around this I either back up at idle only or while in neutral quickly pump throttle to 100% I can feel what I think is TV cable bind very lightly. Prir to my rebuild I could not get any throttle In Reverse when warm as above. Sorry I don't have a real solution yet. My trans guy is having a look and ill post the repair then. It's likely a valve body circuit issue as it only happens while the vehicle is running and only when warm. Typically my trans runs 115F and is fine.
Renteria1217
For Sale
Aug 16, 2015 09:43 PM
Nu2cummins
Jun 26, 2015 02:30 PM
gd1996
For Sale
May 15, 2015 09:42 AM
97boatstroke
Dec 22, 2014 09:54 PM
mtedrick4
Diesel Engine Conversions
Oct 13, 2014 09:25 PM
