Miss?? Injectors??
Old Mar 19, 2013 | 10:26 PM
eddie7644's Avatar
Default Miss?? Injectors??
Ok so I have a slight miss you can hear it from the exhaust. Is this normal when I took my injector lines off to remove the injectors no fuel came out but they spit fuel like crazy when it is running is that right?? I removed my injectors and the nozzles were black and seemed clogged. If I clean them will it work and could that be my miss??
Old Mar 20, 2013 | 05:35 PM
mytrucksmokesmorethanme's Avatar
It could help, problem is that the ports on diesel injectors are very small for a reason and if your not careful you could do more damage than good, if money is a issue, than give it a whirl , might want to soak the injectors first
if you have some money , just replace them, if you have only a little money send them out and have them flow checked
good luck
scott
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
