gear ratio help
Old Mar 19, 2013 | 10:00 PM
kris_97_7.3's Avatar
Default gear ratio help
OK guys i need some help, I have a 97 f250 4x4 automatic. I need help finding out what ratios in it. I run at 2000 rpm going 70 on 33x12.50's. I was told 4.10's but i don't think that is right. I need help quick. I have not had a chance to check the code, could some tell me exactly where to look? Thanks in advance for any help.
Old Mar 20, 2013 | 09:52 AM
Slim Whitey's Avatar
take your vin and go to any ford dealership. they should be able to punch in the vin and tell you *everything* about your truck.
if you cannot do that physically, there may be a way to do it online.
Old Mar 20, 2013 | 10:30 AM
POWER-STRUCK's Avatar
sounds like you have 3.55s, just check the tag on the diff cover
Old Mar 21, 2013 | 02:49 PM
7.3OilPanRepair's Avatar
FormerVendor
yeah, I have 4.10s and im usually around 2500rpm at 70mph. stock tires though 235/85 r16 i think
Old Apr 2, 2013 | 04:45 PM
thorraven's Avatar
you have the 3.55. if you had a 4.10 your rpms at 70 would be about 2900rpm. you can also use this calculator to double check other things too, but i would bet you have a 3.55.
remember calculate the gear ratio, WITHOUT using overdrive as it is under a 1:1 ratio..
SummitRacing.com
Old Apr 3, 2013 | 12:44 AM
joebob3093's Avatar
Moderator
the door tag has an axle code. google that code and ta da you have your answer. these either came with 3.55s or 4.10s, you have 3.55s
Old Apr 11, 2013 | 11:49 PM
Grizzly_Diesel's Avatar
i have the sales receipt from my 1995 7.3 and it says it has the 4:10 gear ratio. but it was an extra with the truck. so it is possible but its more likely yoiu have the 3:73 gearing.
Old Apr 11, 2013 | 11:58 PM
MossBack's Avatar
SummitRacing.com
I have 4.10 and run 285/75r16 and at 70 mph I'm at 2300rpm. I have video....
Old Apr 12, 2013 | 12:29 AM
joebob3093's Avatar
Moderator
no OBS pickups ame with 3.73s. the only options for the F250 and F350 were 3.55s or 4.10s
corksil
Aug 2, 2015 10:19 PM
Jun 4, 2015 09:30 PM
bigdaddy0608
Feb 26, 2015 04:52 AM
rtbcoop
Nov 29, 2014 11:33 PM
Oct 18, 2014 10:52 AM
