Early 04 no start help?
Old Mar 19, 2013 | 06:39 PM
Powerstroking814's Avatar
Default Early 04 no start help?
I've got an early 04 that will crank but no start...
Batteries tested good, no smoke, ficm tested funny? Key on starts at 30v then goes up to 48v?cranking 48v, ipr actual while the cranking was only 350psi which is too low. I still need to check low oil pressure and icp duty cycle..
Any ideas?
Sent from my SCH-I535 using Tapatalk 2
Old Mar 19, 2013 | 08:55 PM
bobfbigman's Avatar
Yeah, do check low pressure oil and also go ahead and unplug the ICP sensor connector to eliminate a bad ICP from causing the no start, if you have good low pres. then the high pres pump is probably dead, Did it happen all of the sudden or were there signs of somthing not right for a while?
Old Mar 20, 2013 | 08:25 AM
The hpop was replaced 11000 miles ago by ford... They said it just died coming into the parking lot. But it ran fin all day
Old Mar 20, 2013 | 02:02 PM
bobfbigman's Avatar
check your low pressure first, then if that is okay pull the IPR and make sure the screen is not torn or clogged, it is common for the IPR to get clogged after HPOP replacement but it usually happens sooner.
Old Mar 20, 2013 | 04:34 PM
Cinchup88's Avatar
I can't remember been awhile since I've worked on a 6.0L but I do know to pull your intake sensor and check the soot and if its clogged thats a start. I know we had a ton of them come in with a blown EGR (thats an EGR sensor can't recall what it is actaully called)
Old Nov 29, 2013 | 11:38 PM
ZeppelinGTO's Avatar
Were you having the low no power issue with until warm?
Cavnar
Sep 9, 2015 07:18 PM
ish1521
Aug 26, 2015 08:42 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
