Need Help! Have video to explain.
Old Mar 18, 2013 | 05:29 PM
DodgeTime's Avatar
Default Need Help! Have video to explain.
Okay if you watch my video it will be a lot easier to understand then me typing it, im not good at explaining things.
*******I WILL HAVE THE LINK UP FOR THE VIDEO AS SOON AS IT UPLOADS ON YOUTUBE.**********
Only Codes
P0222
Symptoms
-No Power
-Revs Fine in park
-Wont go above 1700 RPM's in Drive
-Matted to the floor absoultly no power slowly gains speed.
-If you really push hard the tranny sort of slips into a lower gear and revs really high then catches.
Only Thing Changed Recently
-Put new negative ground post on drivers side battery, started truck and this problem occured.
-I did have a p0236 and p0237 code but once I unplugged my quadzilla these went away.
-Check ECM ground strap, checked ground off battery's, cleaned posts, grind-ed paint and oil off frame where ground was to make sure it was okay.
-3 days before this problem occured i did put a lock up switch on but i had it hooked up right, i had the jumper wire in the transmission relay like it is supposed to be.
Not Sure About
If I plug my quadzilla back up and turn the power all the way up on a custom tune i have if. I hit the throttle a tiny bit, it gains speed decently, then about 1/4 throttle itll just let go and ill have all the power in the world. Well I shouldn't say all the power but it is definitely working good, it is still not as powerful as that tune would have been before this problem occured, next, the smoke... in drive if i floor like on this tune on level 10 it usually will be crazy but now its hardly any... but if i put her in park or neutral and rev it high she smokes like she used to...
Old Mar 18, 2013 | 08:28 PM
DodgeTime's Avatar
Here's the video
Check out this video on YouTube:
Old Mar 18, 2013 | 08:35 PM
Bryce's Avatar
Set your quad to show throttle % and see if you are getting the full range from the apps.
Old Mar 18, 2013 | 09:00 PM
DodgeTime's Avatar
It goes to 100%
Am I looking for jumps in the percent?
it popps like crazy when I get on it
Old Mar 21, 2013 | 08:32 AM
DodgeTime's Avatar
..........bump no one seems to wanna help me out I replaces my map sensor didn't work I have .8 volts at map sensor plug I checked voltage coming out of the ECM harness too and it's .8 does this mean the ECM is bad
Aug 7, 2015 05:10 PM
Mar 11, 2015 02:10 PM
Feb 24, 2015 04:00 PM
Dec 17, 2014 04:20 PM
Oct 11, 2014 06:25 AM
