6.0 won't start!!!!
I have a 2005 f550 with a 6.0. The injectors were giving us fits so we replaced all of them along with new standpipe and plugs. It ha been running perfectly for 2-3 months and now, all of the sudden, this morning it wouldnt idle worth a crap. When you try to start it it would just start super slow and then finally catch and spudder and shake like only half the cylinders were firing.
We put it on our genysis scanner and got these codes:
P0611 ficm
P0262
P0270
P0277
P0278
P0280
P0284
P0528
We read that injector codes coupled with the ficm code told us the ficm was bad. We ha suspected this for a whole but this convinced us. So we replaced the ficm half she'll and it did not fix the problem. We have good logic and and vehicle power. Also ficm power never drops below 47. We are at a loss.
Also, upon first start up the blew black smoke pretty heavily.
Also the truck is running very loudly on top of loping at idle.
P0611 ficm
P0262
P0270
P0277
P0278
P0280
P0284
P0528
have you cleared codes and see which ones reset? Are you sure ficm connectors and connected fully? Oil level good? fuel press good? Also check battery connections specificly the one ten mm nut the holds the power cable to the ficm on the driver side batt. post cable end.
check the filter inside the frame rail if you see what looks like silver whitish paint chips thats bad probably took the pump out check and see if the top filter housing fills up the silver paint chip **** is from the **** in the tank iv seen this tons of time at our shop with the 6.0's and it also takes out injectors like its its job
Cavnar
Sep 9, 2015 07:18 PM
Accubuck
May 7, 2015 04:46 PM
cjgregory
Mar 31, 2015 01:45 PM
thumperf350
Jan 8, 2015 12:55 AM
