2001 GMC Savanna 3500 6.5L Non-Turbo is not starting!!!
Old Mar 18, 2013 | 01:12 PM
bigwillofmd's Avatar
Default 2001 GMC Savanna 3500 6.5L Non-Turbo is not starting!!!
I ran my van out of fuel and I have been having issues starting it. I changed the fuel filter, topped it off with diesel and it started for a minute. The van is not starting now. My glow plugs are not getting 12v at the glow plug connectors, so I replaced the GP relay and the GPs. I am still only receiving around 5v and the GP connectors. The batteries are fully charged. Could someone please point me in the right direction?
Old Mar 20, 2013 | 01:10 AM
cviola2005's Avatar
Are your batteries fully charged?
Old Mar 20, 2013 | 08:47 AM
racer55's Avatar
Sounds like a connection problem or corrosion in your battery cables-good chance the cables going to the battery under the floor might have road grime contamination?
Have you checked both heavy terminals of the glow relay for voltage when the glows are cycling to see if they are the same voltage?
High resistance at a ground connection can result in the same problem,after some extended cranking-say 10 seconds,quickly get out and feel the battery cables with a bare hand-the one(s) that feel hot/warm to the touch need attention.
Old Mar 20, 2013 | 09:01 AM
Thanks guys! I will check the batteries.
Old Mar 20, 2013 | 04:32 PM
Mayhem's Avatar
Dont forget to check and clean the grounds these lead to the type issues you are having as well
Old Mar 20, 2013 | 06:00 PM
I am getting a drop to 5V, when the GP relay cycles. It would seem like a bad battery or cables as you stated. It should remain 12V? Do you know where I could order all of the cables? Ebay has a set for around 250.
Old Mar 20, 2013 | 06:30 PM
Mase's Avatar
Every once in a while you can find wrecked semi's with good cables if they haven't already been taken and they have very good cables.Goggle semi junk yards or semi used parts in your area.Sometimes there cheap sometimes not.
Daniel Finney
Oct 22, 2019 01:58 PM
Jet A Fuel
For Sale
Aug 16, 2015 04:44 AM
zman577
May 11, 2015 06:50 PM
MrMoose
Mar 15, 2015 06:05 PM
duanedwc
Dec 13, 2014 12:36 PM
