Steering problem.
Old Mar 17, 2013 | 10:42 PM
dieseldude848's Avatar
Default Steering problem.
Something is up with my steering when I turn the wheel right a little bit almost like somthing is loose, I can't hear any noises, I just feel it in the floor board. Almost like its being hit with a rubber mallet. Everything seems tight under there... Any ideas? Truck does not have death wobble, and doesn't wonder on the road that bad.
Old Mar 18, 2013 | 12:51 AM
97cummins's Avatar
Are the rear steer axle shackles loose?
Old Mar 18, 2013 | 07:31 AM
The rear U-bolts or the rear leaf spring shackle bolts? im confused as to what you mean by "rear steer" the rear U bolts are not loose...
Old Mar 19, 2013 | 08:42 PM
Bump. Any ideas?
Old Mar 20, 2013 | 06:30 PM
Elimin8r's Avatar
This sounds like a track bar thud/clunk. Have you shook it around to see if there is any play? There should be none at all.
Old Mar 20, 2013 | 08:00 PM
i recently replaced the lower bushing, and the upper ball joint link wasnt loose, but not super tight. the lower bushing was smoked, and never made a clunk.
Old Mar 20, 2013 | 10:01 PM
RAW's Avatar
RAW
Radius arm bushings?
Old Mar 21, 2013 | 08:41 AM
Elimin8r's Avatar
I had the same symptom of a single clunk/thud I could feel in my feet when turning off-center. It was my bushings (I have the 3rd gen bar/bushings). My bar would make a small knock when I would crawl under and shake it. However with the weight of the truck it magnified by 100x. When you turn the wheels, and the axle relies on the track bar to keep it centered under the truck the problem would happen.
I am not saying for sure that is it, but if you have play in it at all, it could be the source.
Good luck!
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
ramrunner01
Jun 1, 2015 12:10 AM
BubbaDT55
Apr 12, 2015 10:47 PM
sweetv8s10
Oct 7, 2014 09:47 PM
