hx-35???
Old Mar 17, 2013 | 07:18 PM
firstgenfreak93's Avatar
Default hx-35???
Hey guys, i think i am making to much boost and flowing too much fuel for my little h1c to handle..my 25 psi gauge is maxing out at a half throttle 3rd gear pull...i am also smoking more than i would like...i dont even have injectors yet but plan on them soon...will an hx-35 fit my needs or should i go hx40...also, after this turbo upgrade and injectors, will i still be below 50 psi of boost because i am buying a new gauge soon and dont want another one too small...also will the new turbo bolt right on with ease or is it a little difficult..and my h1c does not have a wastegate so can i get a non-wastegated 35 or 40
Old Mar 17, 2013 | 10:40 PM
Cow tipper's Avatar
An HX35 will more than likely blow at 50 psi. If I was you I'd go with an HX40. But yes the HX35 does bolt right up to it. You just need an oil line from a second gen because the fitting on the HX35 is smaller than the H1C for some reason. I think the HX40 will bolt right up also but im not 100% sure.
Or put a HE351vgt on it from a common rail cummins
and you can weld the wastegate shut
Last edited by Cow tipper; Mar 17, 2013 at 10:40 PM. Reason: Automerged Doublepost
Old Mar 17, 2013 | 11:22 PM
Willey878's Avatar
Any more then 30 35lbs and you could lift the head if you haven't already studed it
I just did my hx35 swap 3 days ago and loving it I'm using my gate to be on the safe side im only making 25lbs till I throw in my boost elbow then 30 my pumps pushing as much fuel as I can with the screw and star wheel all in stock injectors Not much of a smoke difference going from the h1c way faster spool time tho egts difference was minimal
I do believe the hx40s have a much weeker shaft then the 35 to
Old Mar 17, 2013 | 11:26 PM
Al31031's Avatar
the hx35 will bolt right up just make sure you have the right manifold flange (t3-t4) i had an hx35 see almost 60lbs for almost a year before it blew and it had 230k on it your gonna want head studs though if your thinking about that much boost, and the hx40 is a nice lil upgrade from the 35 but more than likely it will have a wastegate on it already wich you can adjust with an elbow as im sure you know but with near stock work you have done i found the lower boost range of around 30-40 worked best on my p-pumped 12v obviously much more than stock but safe for the turbo and a great power increase anything more i felt it was over kill
Old Mar 18, 2013 | 04:02 PM
thanks guys, i will do the turbo first and then headstuds...i thought the factory head bolts would hold up to more than 35 psi but i guess better safe than sorry...headstuds it is
Old Mar 24, 2013 | 08:17 PM
DMan1198's Avatar
I ran my cummins at 38 then 42 for months with no issues
