truck died and won't start
Old Mar 17, 2013 | 04:16 PM
cumminskid92's Avatar
Default truck died and won't start
my dad started his truck this morning and after about a minute it died. it ran fine right up until it died. when it died it did not stumble, smoke or anything. it just shut off like someone turned the key off. it is completely stock other than a F.A.S.S. system and a small programmer. where do we start. I don't know much about vp44 trucks
Old Mar 17, 2013 | 04:25 PM
dolla_hite's Avatar
check fuel psi and check for codes.
Old Mar 17, 2013 | 05:44 PM
Al31031's Avatar
check the pressure like doll_hite said one of the pumps prolly **** the bed iv never really heard of one just bam no sign of going out but i would say start there for sure the lift might have went out or just seized or was going out and fried that vp maybe hard to say with such little symptoms
Old Mar 17, 2013 | 07:47 PM
Bryce's Avatar
How much fuel is in the tank?
Old Mar 17, 2013 | 09:43 PM
barnburner01's Avatar
def check the fuel level! never fully trust the fuel guages in 2 gen trucks!!
Old Mar 18, 2013 | 08:51 AM
the tank is full. the only code it is showing is p0234. which I believe is over boost. so that shouldn't have any effect. does the vp44 have a shut off solenoid that could have possibly gone bad
Old Mar 18, 2013 | 08:25 PM
Bryce's Avatar
If the horn works swap the horn relay and fuel relay. If you bump the starter the lift pump should run for about 25sec. Can you hear it running? If so, loosen injector lines 1,3,&4 at the head and see it you are getting fuel to the injectors.
