Lower EGT's please
Old Mar 17, 2013 | 03:59 PM
Oil Igniter's Avatar
Default Lower EGT's please
Greetings, I'm looking for the best and most cost effective way to lower EGT's while hauling. As of now I do not have too much trouble with temps while pulling my boat(4500lbs). Looks like a may be adding an old school camper( circa 1978-made of lead, bricks, and concrete) I just know its heavy and will be acting like a sail.
Ready for suggestions to get temps down. I appreciate the input.
Old Mar 17, 2013 | 04:33 PM
RAW's Avatar
RAW
Colt stage 3 (BigStick) Camshaft will make a significant difference for the price. If that is a bit to complicated, a bigger turbo will work as well. Turbo will likely cost more money, unless you did a HX35/40 Hybrid kit.
Old Mar 17, 2013 | 05:59 PM
Mopar1973Man's Avatar
______
'02 2500, NV-4500, 120 noz, air intake, Air Dog II, Edge COMP, 5", banks brake, auto meter, 35"s
35's are adding a bunch rolling resistance. Like myself I went the opposite direction small lighter wheel and tires. Less face on the ground less rolling resistance. Less tire mass and weight less rotational mass to sling around the axle.
Cold air intake won't do much. Being the discharge temp of the turbo will be 300-400*F before entering the intercooler. So the intercooler has more to do with intake temps.
120 HP injectors a bit big for towing application. Like RAW suggested you could go bigger in the turbo and or cam. But I would suggest backing down from the 120's and dropping to 75 HP or so. Much more controllable.
Like myself. I've got no problem hauling my RV/Utility Trailer over the steeps grades of Idaho.
Old Mar 17, 2013 | 08:00 PM
JBearSVT's Avatar
I've often wondered why I never hear about anyone upgrading intercoolers in here.
Old Mar 17, 2013 | 08:27 PM
RAW's Avatar
RAW
Likely because they are well over $1000, and a stock air to air will get you 600HP.
I have 150HP injectors, tow a 38' Holiday trailer weighing 12,000lbs with 35" rubber and my EGT's rarely ever break 1200*. Granted I have compound, Cam, and a bunch of other goodies.
Replacing your injectors again will cost the same, if not more, than going to a HX35/40 Hybrid. I believe the Hybrid will give you the best of both worlds. A reduction in EGT's, increase in power, and minimal drivability difference.
Old Mar 17, 2013 | 09:20 PM
And if one were to be in the market for a HX35/40 where would one locate?
Old Mar 17, 2013 | 09:28 PM
RAW's Avatar
RAW
Ask the Vendors in the Price Quote section, they will likely get you the best price.
Here is a link to one:
Stage 3 Power Compressor Upgrade w/60mm Wheel 95-02 Dodge Cummins
It isn't for your exact truck, but very similar.
Old Mar 17, 2013 | 09:52 PM
barnburner01's Avatar
high tech turbo sells some great turbos, they have a 35/40 or you can upgrade your 35 with their parts, i you do upgrade watch your boost, without studs i wouldnt go much above 35-40 psi to keep the headgasket in place
Notdaddysmoney
11
Oct 23, 2015 12:52 AM
CCPerformance.com
Chevy/GMC Duramax 2011 LML
Sep 1, 2015 11:37 PM
CumminsCoalRoller24/7
May 25, 2015 09:04 PM
Moparts345
May 24, 2015 09:35 AM
Curry
Apr 20, 2015 04:04 AM
