04 5.9 no fuel peddle after turning off cruise
Hey guys, newbie here.. My 04 2500 with 5.9 is acting up. I have programmer and cold air intake with 5" exhaust. For a little while now it goes to idle, mostly when off fuel and trying to pull out( no peddle) then all of a sudden picks up n runs strong! Also odometer work intermittently, I was using cruise yesterday and when I touch brake to turn off cruise, truck went to idle (no fuel peddle) at 70 on interstate! I did a code check and reviled po500 .. Any ideas on what's goin on? What's the fix? Thanks
It's on top of the rear diff housing. Sell it on Craigslist or ebay.
I unhooked speed sensor and connector was clean and water free.. Could sensor be bad? Is it dealer only part? Thanks
I bought new speed sensor at advance auto parts 32.00 installed abs lights still on. Any reset needed??
Changed sensor ,, still acting crazy.. Help
Could be a wire issue also check the ecm connector and clean your battery connections just because! These issues are hard to track down almost worth taking it to the dealer let them scan it!
