filter delete
Old Mar 16, 2013 | 07:54 PM
Al31031's Avatar
Default filter delete
iv seen a lot of fuel filter delete kits for the common rails but none for the vp 24v's i was just wondering why because i would like to delete mine my air dog is bypassing the housing anyway so no fuel heater so i wouldn't see why i would miss it . Any input from someone who has done this would be gratefully appreciated stupid question i guess
Old Mar 17, 2013 | 08:34 AM
Mopar1973Man's Avatar
I personally kept mine for 2 reasons.
1. The fuel heater since my winter temps are as low as -20*F to -30*F in the dead of winter.
2. The extra filter even though I'm using a 3 micron Donaldson filter on the AirDog 150 the stock filter still gets darken over a period of 50K miles. So I consider it a secondary catch all filter protecting my $1,000 dollar VP44. More filtration is better than not enough. Even CR owners typically run a double stacked filter setup to protect their $3,000 to $4,000 dollar injectors.
Suggestion if it was me I would keep it. Because even with mine I only see about 1-2 PSI drop from Idle to WOT...
Old Mar 17, 2013 | 09:29 AM
RAW's Avatar
RAW
I kept mine for the same reasons, but will be removing mine. I will loose an extra layer of protection, but will have a fuel heater. I bought the electric fuel heater for the FASS pump.
No kit is required. Just unplug the WIF, and fuel heater, unbolt the housing, and away you go.
Old Mar 17, 2013 | 01:07 PM
Al31031's Avatar
see how the two lines on the bottom connect in the delete i cant find this setup for the vp 24v this one is for a cr how would i go about doing this or are those just the old feed and return?
Old Mar 17, 2013 | 01:34 PM
RAW's Avatar
RAW
Those look like feed and return. The VP44 engine has an independent fuel return circuit. The return from the VP tees into the return from the head, and from there it has its own line back to the tank. That is why a kit isn't needed.
Old Mar 17, 2013 | 02:29 PM
Al31031's Avatar
so if my airdog bypasses the filter canister i just take the canister off thats it?
Old Mar 17, 2013 | 02:42 PM
RAW's Avatar
RAW
Yep, there is no fuel flow through it right now. Chances are its half empty, if not completely empty right now.
Old Mar 17, 2013 | 03:01 PM
Al31031's Avatar
Do I still have to fill the holes with bolts?
Old Mar 17, 2013 | 03:06 PM
RAW's Avatar
RAW
Yes, with shorter bolts. The bolts that hold the assy on also hold down the intake plate. Without the bolts replaced, the plate gasket may pop out.
Old Mar 17, 2013 | 05:30 PM
Al31031's Avatar
thanks a lot guys so much more room now
jeffersonl
Nov 15, 2015 07:35 PM
willyam
Price Quote - Request A Price
May 19, 2015 10:20 AM
Bob V
Apr 6, 2015 11:02 PM
jeffersonl
Oct 25, 2014 06:46 AM
james2562
Oct 8, 2014 06:14 PM
