KSB leak!??!??
Old Mar 15, 2013 | 11:40 PM
Buckshot927tx's Avatar
Default KSB leak!??!??
I just put my new(rebuilt) ve pump on and now my ksb is leaking?!! My old pump was leaking too just in a different spot... Why do these little ve pumps leak so much!??! And how do i stop this ksb leak?
Old Mar 16, 2013 | 10:09 AM
Screamin' Metal's Avatar
1st of all, we need to know WHERE the KSB is leaking. At the fuel line coming into the top? At the screw in plug towards the front, toward the radiator? Between the KSB and the Pump?
There are seals and gaskets there....on the top where the fuel line screws in, if its dripping there, as quit a few do, try snugging it some more with a line wrench. Don't use a regular open end wrench, that not rounds off easily, and when it does, can be a bitch unless you put vise grips on it....
However, I've seen the flair crack on the metal tube from being over-tightened, alot of times, just have to put a new line on.
Now, again, where is this puppy leaking at?
Old Mar 16, 2013 | 10:17 AM
Well, on the back side if it closest to the driver, there is a pretty big sized brass fitting, it seems to be leaking a little from the bottom of that fitting. Also, i feel i should mention that i have done all the normal tweaks to the pump. Advanced timing, totated pin, tightened smoke screw, screwed down star wheel, and turned in power screw a couple turns.
Old Mar 16, 2013 | 10:42 AM
Theres a oRing or a flat seal back there, probably needs replacing....just under that screwin plug.
Old Mar 17, 2013 | 03:30 PM
Guess i'll losen it and take a look, i have a rebuild kit on stand by thanks
Well, took a wrench to it and she was waaaay lose straight from the rebuild shop, tightened her up and no leaky leaky thanks for the help guys
Last edited by Buckshot927tx; Mar 17, 2013 at 03:30 PM. Reason: Automerged Doublepost
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
InheritedDiesel
Jun 3, 2015 09:39 PM
blue ox
Feb 19, 2015 08:38 PM
ash23k
Dec 30, 2014 08:31 PM
Dec 5, 2014 08:30 AM
