How cold is to cold?
Old Mar 15, 2013 | 08:58 PM
Mase's Avatar
Default How cold is to cold?
I don't know if this is a problem or not.Most of you wish for it.I just rebuilt engine before I rebuilt it always ran 180/185 now with 4in exhaust and duramax fan 155.I figured maybe just cause its been cold here in indiana.First I thought gage since it dont move but I shot it with electronic thermo gun and no matter were you shoot(engine,manifold or exhaust)152 to 158.Today was 62 degrees outside I ran 60 mile an hour for a hour with heater shut off same thing didn't get warm enough to show on gage.this should not hurt any thing should it.
Old Mar 16, 2013 | 04:25 PM
racer55's Avatar
For economy and best power you want as close to a constant 200F as you can get.
Sounds like you used aftermarket T-stats that are notorious for not working in these engines.
AC Delco ONLY.
Old Mar 16, 2013 | 07:05 PM
Mase's Avatar
Thank you for the info I will replace them tomorrow.
Old Mar 19, 2013 | 06:03 PM
Mase's Avatar
Wrong t-Stat every thing good now.Thanks racer 55
Old Mar 19, 2013 | 06:13 PM
racer55's Avatar
Good to hear.
Old Mar 19, 2013 | 06:33 PM
Mase's Avatar
I should have known better than to get it from O'reilys never had any luck with anything from there except filters.
Old Mar 19, 2013 | 07:16 PM
Mayhem's Avatar
You can get AC/DELCO T-Stats at Oriely's but they have to order them the only part in AC/Delco I havent been able to get there Is my brake switch
Old Mar 19, 2013 | 08:06 PM
Mase's Avatar
I probably need to clarify that.The 2 close to me have good parts but don't have employees that no there a-- from a hole in the ground.Dident want to bad mouth hole outlet.
Old Mar 20, 2013 | 01:06 AM
cviola2005's Avatar
My 6.2/6.5 hybrid motor runs around the same temp. I have never even looked at my t-stats the entire I've had my truck. The only time mine runs warmer than that is when I'm towing. I have never gotten double digits in fuel economy. I get between 4-8 MPG. I will definitely change my t-stats when I rebuild it next month.
Mike0885
May 27, 2015 12:07 PM
iMixDiesel&Gas
Dec 27, 2014 09:57 PM
custom7.3
Nov 24, 2014 05:16 PM
custom7.3
Nov 23, 2014 10:44 PM
12vbomber
Nov 4, 2014 10:04 PM
