Fuel filter replace
Old Mar 15, 2013 | 05:28 PM
kraftdinner's Avatar
Default Fuel filter replace
Hey all I'm doing a few small things to my rig tomorrow morning and one of them is the fuel filter correct me If I'm wrong but I just need to loosin off the bleeder then the bigger black ring and remove old filter then put new one in, unscrew bleeder and crank engine till fuel comes out ?
Now the filter i got from napa has the black ring built into the filter, will this still work on my 6.5td s vin ?
Thanks in advanced !!
Old Mar 15, 2013 | 10:38 PM
Mayhem's Avatar
save the wear and tear on your atrter and batteries and run a wire from the positive terminal on one of the batteries to the G terminal on the ALDL port under the dash and you can run just the lift pump to prime the fuel system
Old Mar 16, 2013 | 02:49 AM
Oh cool! Thanks a lot man, so that filter will work ?
Old Mar 19, 2013 | 12:32 PM
klein444's Avatar
Default Yes
I have used the Napa filter before. Just be sure to keep your plastic ring incase you go back to a fuel filter that does not have it as part of the filter like the one from NAPA does. In my opinion it was a very nice fuel filter.
~GOD BLESS~
john
Old Mar 19, 2013 | 06:15 PM
Mayhem's Avatar
Napa gold filters are the same as WIX filters Napa gold are all I use in my vehicles dont know if they do it where you live but here every other Friday is half price filter day at Napa .
Old Mar 20, 2013 | 01:09 AM
cviola2005's Avatar
Mayhem: Is that the Napa in Cookeville or Livingston?
Old Mar 20, 2013 | 05:43 AM
Mayhem's Avatar
Cviola it's the Livingston Napaand if I am not mistaken it is the first and second Friday's of the month that they do that
Old Mar 21, 2013 | 01:17 AM
cviola2005's Avatar
Thanks! I'll try to get up that way again to check it out. Wix makes a good filter, and any deal is a great deal.
When I'm changing the fuel filter, I unplug the OPS and use a jumper wire between the outer two terminals on the plug to run the lift pump. Its essentially the same process as using the ALDL connector and a battery, but this way puts both connections right near where I'm at. I think its easier, but to each their own.
Last edited by cviola2005; Mar 21, 2013 at 01:17 AM. Reason: Automerged Doublepost
Dbleo351
Nov 20, 2016 09:34 AM
jeffersonl
Nov 15, 2015 07:35 PM
moneypitk5
Feb 12, 2015 11:01 AM
jeffersonl
Oct 25, 2014 06:46 AM
james2562
Oct 8, 2014 06:14 PM
