external voltage regulator charging at 24volts .... help
Old Mar 13, 2013 | 10:25 PM
mdub4life29's Avatar
Default external voltage regulator charging at 24volts .... help
so im having a problem. i used the mopar external regulator that was said to be used. i am funnring my cummins and it am getting 24 volts to the battery from the charge wire to the battery from the alternator. i wired the key on power to the top terminal on the pyramid and the other wire to the other terminal on the alternator....... my question is did i do something wrong. the other thing i am wondering is.. i hooked key on power directly to the terminal on the back of the alternator that the top pyramid terminal on the regulator is hoooked to. i am confused why it didnt work??
Old Mar 16, 2013 | 09:47 PM
Screamin' Metal's Avatar
I answered this question over on the other board you posted this on....just rewire to the schmatic that was enclosed....take your time and do it right. Also, if you add the external regulator....disconnect the ECM from your charging system.
Old Oct 4, 2014 | 02:36 PM
I wired it to the schematic that came with it but I am still having problems
john grossman
10
Jan 12, 2019 08:58 PM
robbyS
Apr 16, 2015 02:22 PM
