6.5L TD stalls
Old Mar 12, 2013 | 08:37 PM
Captains booty's Avatar
Default 6.5L TD stalls
i have a 1994 6.5l turbo. i have relocated the pmd. i have not made sure i have fuel to the injectoes but i do have fuel to every where else. Just like alot of other people have reported my truck just stalls like it ahs been shut of.
if it matters the truck is a K2500 HD.
this is my first diesel so i do not know very much but i am a little mechanically inclined so i learn quickly.
Thank you in advance for any help you can give.
Old Mar 12, 2013 | 08:51 PM
Mayhem's Avatar
Please copy and paste and fill out the following link and we will do our best to get you sorted out the more we know the better we can help you
Diagnostic Checklist version 2.0 [10-2009] - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Old Mar 12, 2013 | 09:16 PM
MontanaTechPetroleum's Avatar
Clean the connections on the pmd. I had a frayed wire on mine it would rev up and down at idle and shut off when I was driving. I fixed the wire and blew out all the dirt that was in the connections and been working good sense. There was dirt in the connection since it was in New Mexico, just dust and dust and more dust.
Old Mar 13, 2013 | 06:18 PM
1. Describe the problem you are having in detail:
2. Year of truck/engine.1994 6.5L turbo
3. Odometer reading (indicate miles or kilometers).216,000
4. Indicate the model number on the Injection pump (starts DS4 or DB2......).unsure
5. Indicate if you know if it’s a 1500, 2500, 2500HD, 3500, 3500HD.2500hd
6. Do you have an EGR on the engine ? (An F or an S engine code 8th VIN digit)F engine code
7. Air Filter condition (visual check).good looking K&N
8. Fuel filter condition (freshly changed, mileage since changed).changed 1000 mile or less
9. Location of PMD/FSD? (ex. on pump/remote over intake, behind bumper).relocated to bumper
9a. If remote mounted, describe wiring harness (homemade or purchased from which vendor).bought online from store in Florida
9b. Indicate the location and condition of the FSD/IP grounding wire.unsure
10. Outside Temperature (C or F). _____ °curently 35 degrees but has bben around 60 when it has happened and since it hasn’t started
11. Service Engine Light while running?- on/off/intermittentno
11a. Service Engine light does glow during start/cranking/bulb check: Yes/No bulb works
12.Have you scanned for engine codes? Yes/No have not scanned
12a. List exact results on engine codes.
13. Condition of Battery terminals (removed, cleaned and tightened).look good have not removed but are tight
14. Known condition and age of Batteries.new batteries
14a. Are batteries a matched set of same age?both are new
15. Condition of Major Grounds (removed, cleaned and tightened)the ones I know are tight but have not been removed and cleaned
16. Does engine crank, or "turn over"?engine turns over
16a. Does engine start and run?has not run in several days before this it would start sometimes and not start other times
17. If engine does not start- Crack injector line: do you have fuel? Yes/No have not done this yet
18. Does your Wait To Start light come on?yes
18a.Number of seconds WTS light is lit.10 - 12
19. Engine Cranking speed (if you have an accurate tachometer).unsure
20. Are you experiencing Stalling?when it would start yes
20a. Describe the event (upon startup only, down the road, hit a bump, etc...)stalled while sitting in drive while going down road for no appearent reason
20b. Do you notice loss of dash or instruments?dash continues to work fine
21. Check turbo inlet and air filter for obstructions.have not completed
22. In a no-hot start, pour a bottle of room-temp water on the injection pump. Does it start now?
23. Lift pump test - Describe results.i have fuel that comes out of the t on top of motor
24. Upon cold start, does the radiator hose get hard quickly? Yes/Nounsure
25. Upon cold start, do you have excessive white smoke? Yes/Nosometimes
26. Do you have excessive cranking time before the engine starts? Yes/Nosometimes when it did start in the past
27. Have you used the block heater? Does it affect engine starting? (only try for starting problems).yes I have used block heater unsure if it helped
28. Are all glow plugs in proper working order?unsure do not know what to look for
29. During hard acceleration, do you have excessive black smoke? Yes/Nono
30. Do you have any unusual exhaust smoke issues?no
31. Turbo check out - Pass/Failunsure how to check
32. Indicate fuel that you are using: Bio-Diesel, #2 Diesel, SVO/WVO, otherfuel from bp
32a. If running Veggie Oil fuel setup, indicate details of your conversion (homemade or packaged system).
33. Are you using any fuel additives? If so, please list.none
34. Upon unscrewing fuel cap, do you have a large vacuum formed in the tank? Yes/Noyes
35. Do you have any service history available that might pertain to the problem you are having?
36. Please indicate any modifications to the vehicle that might help us diagnose better. Recently bought the truck no mods that I am aware of
__________________
Old Mar 13, 2013 | 06:35 PM
Mayhem's Avatar
You should not have a vacuum in the tank try running the truck with the fuel cap loose or replace the fuel cap with a new Diesel cap
Old Mar 13, 2013 | 07:36 PM
be loosening the cap or replaceing it will this help it start
Old Mar 13, 2013 | 09:20 PM
Mayhem's Avatar
I can promise you it will but it is a starting point ,how old is the PMD? and do you have a spare?
Old Mar 13, 2013 | 10:13 PM
i am unsure of the age of th ePMD and i do not have a spare but from all of the reading thus far i do know that i need to get one.
i also noticed that the glow plug light comes on and off while cranking the engine.
Last edited by Captains booty; Mar 13, 2013 at 10:13 PM. Reason: Automerged Doublepost
Old Mar 14, 2013 | 05:21 AM
Mayhem's Avatar
It is normal when the GP light when trying to start however you should wait till it's off before cranking and you should give at least a minute between cycles when trying to start or you will kill the starter
Old Mar 14, 2013 | 11:37 AM
racer55's Avatar
The glow light has a series of cycles-start engine after it goes off the first time-additional glow light cycles are afterglow and help when the engine is already running.
*2 for trying a loosened fuel cap.
IP harness ground MUST be fastened to the IP.
Symptoms sound like PMD failure?
