6.5 td small fuel leak
Old Mar 12, 2013 | 06:03 PM
kraftdinner's Avatar
Default 6.5 td small fuel leak
So I've had a small fuel leak for a couple weeks now..
Everytime I seen it under my truck it was just a little puddle I thought it was an oil leak for my pan gasket or something, until I went under the truck today to figure it out and found out it was a fuel leak!
It's leaking right off my starter and dripping on my crossover before it hits the ground! I've been doing some research on google and looks like it's probably 1 of 3 lines that go to the bottom of my fuel filter housing? Or my fuel filter o-ring ?
I'll probably take the 2 bolts holding the housing off tomorrow and inspect the lines as I've read the lines are probably old and got cracked if not the o ring?
Anyone here had the Same leak in the past?
-no performance lost
-ip is a few years old
Thanks!!
Old Mar 12, 2013 | 06:51 PM
MontanaTechPetroleum's Avatar
Probably just a seal/gasket somewheres along there. These things about 20 years old now, so seals/gaskets or anything much rubber are probably going to start falling apart now.
Old Mar 12, 2013 | 07:20 PM
Mayhem's Avatar
My 93 had the O-ring on the bottom of the fuel filter housing go out last sumer producing a leak simular to the one you are having it would leak down a bit when off resulting in a hard to start I got a new O-ring from my local parts house for a $1.00 something I think been good to go ever since the coldest of starts takes maybe 1 second of cranking now
Old Mar 12, 2013 | 07:23 PM
Cold and warm starts are still fine, I'll take it apart tomorrow and post my results for anyone's future problems !!
penley`
Jun 7, 2015 04:38 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
Dec 5, 2014 08:30 AM
