Diesel ??
Old Mar 12, 2013 | 02:39 PM
Andyproenza's Avatar
Default Diesel ??
Will off road diesel hurt the engine and mpg ?? And what are ppl getting mpg as an average.
And what oil do you guys use or is the best ?? Thank you
Last edited by Andyproenza; Mar 12, 2013 at 02:39 PM. Reason: Automerged Doublepost
Old Mar 12, 2013 | 06:49 PM
MontanaTechPetroleum's Avatar
Off road diesel is for off highway use only, such as farm equipment. Its pretty much the exact same as regular diesel without road tax. It's dyed red so they can tell the difference. I think if you're caught using it on the highway its a 2500 dollar fine. Should get the same mileage, but if you're using it for off-roading then you probably not worried about mileage.
I personally run super tech 15w-40, that's mostly because I'm too cheap to spend anymore.
Old Mar 12, 2013 | 07:00 PM
H.R.D's Avatar
Like stated above for red dye diesel, but I run 15W-40 Rotella in mine.
Old Mar 12, 2013 | 07:27 PM
Mayhem's Avatar
A half to one ounce of 2-stroke mix oil per gallon of fuel is a good Idea for these engines the low sulfur diesel they sell nowadays was not made for these engines it will lead to premature IP failure also running the 2-stroke mix I notice my engine is noticeble quieter I buy Pennzoil marine synthectis 2-stroke mix at Wally world for around $15 a gallon small price to pay for longevity I had a 1993 extra-cab with 585,XXX miles on it before the engine went south and those were oil field miles so I would say that it would be closer to 800,000 miles on a normaly driven 6.5
Old Mar 12, 2013 | 07:39 PM
detroitdiesel idi's Avatar
Ive heard that these ds4 inj pumps optical sensor wont work with off road fuel..just what ive "heard".
Old Mar 12, 2013 | 08:30 PM
Does running 2 stroke oil really help, I use that Power Service Cetane Boost stuff in the silver bottle on long trips. Is that basically a lubricant? I know the cetane makes the diesel combust easier. I've heard of running 2 stroke oil in pre-ulsd engines, is the Super Tech company gallon jug good for running in these? Like stated before, I'm pretty cheap.
As for the injection pump not running off road, I don't think that makes any sense. The only difference (that I know of) between off-road and highway diesel is that they add the red dye to it so law enforcement can tell the difference.
Old Mar 12, 2013 | 08:43 PM
Mayhem's Avatar
I put 585,XXX miles running pennzoil marine 2-stroke mix on my other 93 the Injector pump was about the only worth a Darn on the engine when it blew swaped the engine put another 40K on that pump before I sold it the truck started dollaring me to death CV axels fron end new prop shaft every week it was something else I sold it and bought a 94 and unfortuately someone made me a offer I could'nt turn down but I still regret selling that one have 97 K1500 gas burner now and I am so glad I get rembursed for fuel with it as I put at least 500 miles a week on it and get about 12 MPG with it
Old Mar 12, 2013 | 09:07 PM
All I need is maybe another 30k out of mine before I'm out of college and can afford a Cummins, but I like to take care of my stuff, so I'll be buying some Super Tech 2 stroke oil, I don't have to fill up very often, is it safe to let the oil sit in the diesel for a while or does it even matter? Is basically running the Power Service cetane boost the same as adding the 2 stroke oil without the added cetane (really not necessary)? I know that some 2 stroke oil is designed to be very combustible so it could act like the cetane boost anyway?
Boy, as much as I drive, by the time mine has 500k miles, I'll be going to the dealership to buy me a new 2030 Duramax, haha.
Thanks
Old Mar 12, 2013 | 09:34 PM
ricet07's Avatar
I dump my 2 stroke oil in before i fill the tank so the fuel mixes it up good and when I dropped my tank to install my draw straw and AirDog there was no oil settled at the bottom of the tank.
I run rotella 15-40 in my cummins and it seems to like it.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
May 28, 2015 11:45 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
