.040 piston pertrusion
Old Mar 11, 2013 | 04:52 PM
ID Shopteacher's Avatar
Default .040 piston pertrusion
Will a .020 thicker head gasket take care of the problem ? I had to have .015 taken off the top of the block to clean it up so I now have a pertrusion of .040 ! My new gasket at its thickest point around the metal ring for each piston is .095 thick ! and the gasket material is .055 thick !
My question are the thicker Cummins gaskets have a thicker base material plus a thicker ring?
Old Mar 11, 2013 | 10:53 PM
novapat's Avatar
yes the whole gasket is thicker!! I had to take .013 off of my block and took .008 off the head and used a .020 gasket.. compared to stock the whole gasket was .020 thicker. hope that helps ya!
Old Mar 12, 2013 | 01:34 PM
Default Thanks
Thanks much as I had never had to install a "Thicker" gasket !
Old Mar 12, 2013 | 01:36 PM
geddy's uncle's Avatar
be sure to wear your shop glasses
detroitdiesel idi
Jan 2, 2015 02:07 PM
