Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
Solid axle swap
Old Mar 10, 2013 | 10:24 PM
SmokinTide's Avatar
Default Solid axle swap
Under the HD the other day and noticed oily residue on the drivers side of my front axle. I've already been in this p.o.s. twice replacing bearings and seals luckily I've been able to catch it before any worse internal damage was done. Needless to say that bearing on that side has let go again. I've yanked the cv's out and put the old stubs in. Tore the first cv's apart in Ohio a few years back to get me back home and kept them in case that happened again. Am toying with the idea of swapping the ifs for a solid axle. I have done some research but not too extensive yet. I want to go with leaf spring instead of coil overs, I think it would be easier on the pocket book and I don't need that much lift or flex. Probably go with a late model dodge frt ax. I can fab the spring mounts and cross member. What I'm not sure on is the abs, speed sensor and steering hook up. Need some ideas, suggestions or advice.
Old May 2, 2013 | 01:41 PM
Duramax_lly's Avatar
Would also like info on This
Old May 3, 2013 | 01:44 AM
2004LB7's Avatar
Straight axle conversion help - Chevy Truck Forum | GMC Truck Forum - GmFullsize.com
This might help
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
Natenelson1
Jan 19, 2015 07:23 PM
KYLEBOY
Jan 18, 2015 06:36 PM
natenel1
Oct 26, 2014 03:09 AM
blakec
20
Oct 18, 2014 03:35 PM
