A little help with my F350
Hey guys it's been a while since I have been on here. I am going to be doing some work on the front end of my f250 drw. Camber is off on the truck I am getting a lot of wear to the inside of my front tires, tie rod ends are toast and there's a ton of play in the pitman arm. I jacked up the front of the truck and the tires have a lot of play but it looks like its not from the ball joints, going to replace them anyways but it seems like maybe the wheel bearings. If anone can point me in the right direction on what good parts to use with part numbers would be helpful. Also when trying to check fuel pressure from the schrader valve it shows no psi. Did fpr shim to see if maybe it would show so,etching, still nothing. Can that schrader valve be replaced or do you think the whole fpr should be replaced? It was idling pretty rough kind of like a lope. I replaced all 8 injectors with new o rings and replaced the idm and did the idm mod, seems to idle a lot better but still not perfect. When I'm driving down the road I get random boosts of power so I think there's still a fuel issue. If anyone can point me in the right direction it would be much appreciated. Thanks guys!
1ATony
1A Auto Parts
Dec 7, 2015 01:09 PM
1ATony
1A Auto Parts
Oct 26, 2015 02:44 PM
1ATony
1A Auto Parts
Oct 15, 2015 10:58 AM
1ATony
1A Auto Parts
Sep 2, 2015 01:24 PM
1ATony
1A Auto Parts
Sep 2, 2015 01:03 PM
