Steering Stabilizer
Old Mar 27, 2008 | 06:11 PM
torquey's Avatar
Default Steering Stabilizer
just wondering about steering stabelizers for my truck[ 2wd] see sig,i was told some had them but not to sure.there is a bracket on the right frame rail that looks like a mount for one.any info on availability would help, thanks.
Old Mar 27, 2008 | 11:36 PM
LOGANSTANFORTH's Avatar
i dont think so but try fabtech, they might have one for a 2wd, not sure though....
Old Mar 29, 2008 | 08:11 AM
Uncle Bubba's Avatar
By steering stabilizer are you refferring to the thing on the front of the truck that looks like a shock mounted sideways or are you talkin about the cross member that ties the two frame rails together and houses the steering shaft.
If you lookin for the shock type part try doing a search under steering dampener to find what your lookin for.
Old Mar 29, 2008 | 12:25 PM
if im thinking right he needs a shock, there are no steering stiffeners for the 2wd that i know of.....
Old Mar 29, 2008 | 12:31 PM
bow2no1's Avatar
why do you think you need one?
Old Mar 29, 2008 | 12:40 PM
i was thinking that myself.....
Old Mar 31, 2008 | 01:32 PM
greasemonkey's Avatar
the steering box support? yeah, they're available for 2wd's. I have one on the shelf right now that I'm soon putting on my dad's 2wd 97 because the gearbox sector shaft bearing is worn pretty bad. got it from BDPowerDave on here.
from a maintenance standpoint, it's cheaper than a new gearbox; and a new gearbox is going to have the same bearing smoked and seal leaking pretty before too long, just like the last one. as for road feel, the steering feels a fair amount more responsive. I really like the brace.
Old Mar 31, 2008 | 05:18 PM
torquey's Avatar
raised the truck and put 285s on and now my truck wanders more than i like.
Old Mar 31, 2008 | 08:24 PM
It's pretty likely that if you have someone start the truck and turn the steering wheel back and forth in quick little turns, while you've got your hand on the pitman arm, you'll be able to feel or maybe even see the sector shaft sideplay.
with 285's you're a good candidate for the steering brace, especially if it wanders noticeably more with the tire swap. check your sway bar bushings and end links, too; makes a noticeable difference when those things are shot.
Old Nov 5, 2010 | 01:47 PM
EOD Topper's Avatar
Believe it or not I just bought a reconditioned gearbox for my '03 from NAPA for $148.00 plus core and lifetime warranty. The dealer wanted $118.00 for just a new seal.
A stabilizer kit with everything for $189.00 from Larry, see below :
Have questions? Call us any time between 8 am and 6 pm est at 214-414-6470
If you're ready to place your order, just pay below and we will get your dodge steering stabilizer shipped out this week.
model years
'94-'02 Model $189.00 '03-'08 4x4 Model $189.00
Don't forget to check out our other products!
Email:larry@beadseater.net
This site copyright © 2009- 2010 Dodge Steering Stabilizer
Hope this helps you some!!!!!!!
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
sweetv8s10
Oct 7, 2014 09:47 PM
