Please help no start
Old Mar 10, 2013 | 12:42 AM
Pain in the ass chev's Avatar
Default Please help no start
I have a 95 chevy that wont start. Drove it to work and 12hrs later it would just turn over and not fire was running good and then no start. Tried a new pmd and nothing. Took it to the shop and was told it needed a new timing chain. Put it on the trailer and brought it home did the chain and nothing all timing mark lined up the same way it come apart. I think I'm going to start drinking over this truck. This is what I have done so far the truck has 498500km on it and pulls our 26ft 5th wheel. The truck has in order of replacement and all are new. Pmd $450 crank sensor $129 timing chain and gears,$278 injection pump $1899 remove all grounds and cleaned with sand paper and contact cleaner please help. Thank you for any help you give.
Old Mar 10, 2013 | 07:27 AM
Mayhem's Avatar
It would help to have more info as there are many ways that these trucks will not start please fill out and copy and paste this list and we will have a better idea of what is going on with your rig
Diagnostic Checklist version 2.0 [10-2009] - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Old Mar 10, 2013 | 08:07 AM
racer55's Avatar
PMD relocated?Where?
CPS AC Delco?
Old Mar 10, 2013 | 12:27 PM
So to summarize. Do your homework below COMPLETELY. Don't just take for granted something is okay, because it isn't always. Register if you are a guest, and post to verify diagnosis before purchasing parts.
The Diagnostic Checklist:
Please fill out to best of your knowledge.
1. Describe the problem you are having in detail: Truck no start drove to work I turned off and has not started again
2. Year of truck/engine. 05 month of 1995
3. Odometer reading (indicate miles or kilometers).398500 kilometers
4. Indicate the model number on the Injection pump (starts DS4 or DB2......). DS4-5521
5. Indicate if you know if it’s a 1500, 2500, 2500HD, 3500, 3500HD.1500
6. Do you have an EGR on the engine? (An F or an S engine code 8th VIN digit)S
7. Air Filter condition (visual check).New
8. Fuel filter condition (freshly changed, mileage since changed).Changed at last service 1523k ago
9. Location of PMD/FSD? (ex. on pump/remote over intake, behind bumper). 1 on pump and over intake both are new
9a. If remote mounted, describe wiring harness (homemade or purchased from which vendor).harness from pump
9b. Indicate the location and condition of the FSD/IP grounding wire.On pump
10. Outside Temperature (C or F). _____ °3c
11. Service Engine Light while running?- on/off/intermittent was on before working on truck
11a. Service Engine light does glow during start/cranking/bulb check: Yes/No Yes
12.Have you scanned for engine codes? Yes/No yes at the beginning
12a. List exact results on engine codes. 34,36,73,78,97
13. Condition of Battery terminals (removed, cleaned and tightened).Yes
14. Known condition and age of Batteries.rebuilt have been using a 10 amp charger
14a. Are batteries a matched set of same age? Installed at end of October 2012
15. Condition of Major Grounds (removed, cleaned and tightened) removed and cleaned and tightened
16. Does engine crank, or "turn over"?yes
16a. Does engine start and run? No
17. If engine does not start- Crack injector line: do you have fuel? Yes/No no
18. Does your Wait To Start light come on? Yes
18a.Number of seconds WTS light is lit.10-12
19. Engine Cranking speed (if you have an accurate tachometer). Just over 200
20. Are you experiencing Stalling? No wont run
20a. Describe the event (upon startup only, down the road, hit a bump, etc...)
20b. Do you notice loss of dash or instruments?no
21. Check turbo inlet and air filter for obstructions.none cleaned intake when off
22. In a no-hot start, pour a bottle of room-temp water on the injection pump. Does it start now?N/a
23. Lift pump test - Describe results. Put truck in drive open T after 30s about 500 ml
24. Upon cold start, does the radiator hose get hard quickly? Yes/No n/a
25. Upon cold start, do you have excessive white smoke? Yes/No when it did start -15c would have some white smoke
26. Do you have excessive cranking time before the engine starts? Yes/No no start
27. Have you used the block heater? Does it affect engine starting? (only try for starting problems).no
28. Are all glow plugs in proper working order? Yes tested in fall before winter
29. During hard acceleration, do you have excessive black smoke? Yes/No no
30. Do you have any unusual exhaust smoke issues? No
31. Turbo check out - Pass/Fail
32. Indicate fuel that you are using: Bio-Diesel, #2 Diesel, SVO/WVO, other Winter diesel from shell
32a. If running Veggie Oil fuel setup, indicate details of your conversion (homemade or packaged system).n/a
33. Are you using any fuel additives? If so, please list.seafoam 1 time a month and 1 cup ATF per 100L
34. Upon unscrewing fuel cap, do you have a large vacuum formed in the tank? Yes/No no
35. Do you have any service history available that might pertain to the problem you are having? CPS 2 years ago stuck in timing cover 2 days to replace
36. Please indicate any modifications to the vehicle that might help us diagnose better. Stock truck
Old Mar 10, 2013 | 12:39 PM
Mayhem's Avatar
ATF in the fuel is a bad idea it has friction agents in it and over time it will be like running sand paper thru the IP 2 stroke mix is what you should put in with your fuel to add lubricity a 1/2 ounce to 1 ounce per gallon of fuel and I myself am leaning towards a bad PMD mounted under the hood is a bad location due to heat soak
Old Mar 10, 2013 | 12:55 PM
Thank you for the tip on the oil. The pmd are new I bought on and the other come with the pump and nether on has gotten any run time on it I tried all 3 the old one and new ones on a friends 97 and it start right now. Could the ignition switch do any thing. All in all I only have 2 things left the ignition switch and a pcm after all what's left to change.
Old Mar 10, 2013 | 01:08 PM
Mayhem's Avatar
have you got the known working PMD mounted to a heat sink ?? if so try cleanining the ground between the heat sink and where you have it mounted
Old Mar 10, 2013 | 01:59 PM
It's grounded to the ip I'm using the ip harness its just bolted to top side of intake right now will get a cable and run it over to the air box later if I get it running cant put it in the bumper for the water and snow in alberta
Old Mar 10, 2013 | 02:26 PM
Mayhem's Avatar
It's a sealed unit unless you are submerged water wont hurt it but if you dont do the bumper relocate go low in the engine compartment as heat rises and heat is a PMD's worst enemy
Old Mar 10, 2013 | 05:09 PM
racer55's Avatar
No fuel from an injector line while cranking is PMD,IP or ECM-air in the lines or a plugged fuel filter could also be a cause for concern.
The water drain valve is unfiltered fuel so a plugged filter could still be a problem.
Does the fuel shut off solenoid work?
there have been times where the IP driv ley has sheared adn the IP doesn't turn with the timing gears-vry rare and usually from a seized IP but not always.
