violently shaking after clutch install
Old Mar 9, 2013 | 09:07 PM
williehood's Avatar
Default violently shaking after clutch install
I just had clutch replaced on my 1999 dodge 3500 5.9 5 speed drove my truck on highway and the truck started shaking violently had to pull over got under truck everything looked good so drove off was fine for about 2 miles started doing it again took it back to shop they said slave cylinder would that make it shake violent or did they install clutch wrong.
Old Mar 9, 2013 | 10:40 PM
condor74's Avatar
I do not know if your truck is 4wd or 2wd so I may mention stuff you do not have. Does it do it standing still? If you put it in neutral and rev the motor, does the motor shake? If it does, look for a problem with the dual mass flywheel. If it doesnt and only does it when moving highway speeds, I would look at U joints not installed properly, damaged, carrier bearing on driveshaft if you have one, damaged front driveshaft double cardian joint.
Those things are all trans related issues. You may also be describing the death wobble. Most common on 4wd. Any more information would be helpful.
Old Mar 10, 2013 | 10:48 AM
williehood's Avatar
I think it might be that death wobble it sounds exactly like what jerm89 experienced while driving down highway.
Old Mar 12, 2013 | 09:17 AM
condor74's Avatar
If it is a death wobble, check front end components . Make sure the track bar is in good shape. Make sure the steering stabilizer is in good condition and not leaking. A lot of the aftermarket stabilizers are not as good as the factory one. I have repaired many a truck by removing the aftermarket rancho stabilizer and just installing a stock one. Also make sure the the tires are balanced properly. Bigger tires make it harder.
Old Mar 13, 2013 | 04:02 PM
williehood's Avatar
Put new moog track bar in or drag link in today no more crazy wobble thanks for advice
katman
5.9L CR Performance
Sep 10, 2015 03:34 AM
Turbo67
Jul 25, 2015 02:26 PM
lmshowalter
5.9L 24V Performance
Jul 16, 2015 06:39 PM
lkfldredneck
Jun 25, 2015 04:51 PM
Wyocumins
Oct 19, 2014 09:34 PM
