Fuel Pressure
Old Mar 9, 2013 | 05:33 PM
kbradner83's Avatar
Default Fuel Pressure
This is going to sound weird since most topics I have seen are about low fuel pressure. I am running 25-30 psi at idle and around 22 wot! Is this bad? I was told it could be the relief valve on my airdog but I am new to diesels and I am not even sure how to get to the relief valve................ Suggestions ?
Old Mar 9, 2013 | 06:20 PM
Mopar1973Man's Avatar
You too high in pressure I would re-adjust so the max pressure is 19-20 PSI tops. Running high pressure is not suggest and it possible to blow the front pump seal.
14-20 PSI is what I suggest...
Old Mar 9, 2013 | 06:25 PM
BarryB's Avatar
The regulator spring is in the return line. You'll need to pull loose the return line, unscrew the fitting from block, The spring and ball are behind that.
Dbleo351
Nov 20, 2016 09:34 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
cummins Pride
Oct 6, 2014 11:28 AM
