2005 5.9 cummins getting hot at an idle?
Old Mar 8, 2013 | 02:39 PM
Esco1's Avatar
Default 2005 5.9 cummins getting hot at an idle?
When running in stop and go traffic and at an idle, the temperature goes up and my ac starts blowing hot. But when I am on the interstate in stays cool and ac blows cold. I have changed my fan clutch and my thermostat. I have codes of 0480, and 0483 please help before this az heat comes.
Old Mar 9, 2013 | 02:58 AM
97cummins's Avatar
Welcome to dieselbombers, i moved your question to the cummins section for a better reponce. This is the introduce yourself section.
Old Mar 11, 2013 | 05:14 PM
H.R.D's Avatar
Have you flushed the radiator? Got an AC system inspection? May need to recharge the AC.
Old Mar 12, 2013 | 08:01 AM
Esco1's Avatar
No I have not flushed the radiator or had the AC checked. 0480 code says cooling fan 1 control circuit open low speed fan relay, and 0483 says cooling fan speed. What does these codes mean?
Old Mar 12, 2013 | 08:34 AM
dangerous1965's Avatar
The codes mean no power to the fan. Check the connection and for any damage to the harness. As far as getting hot I put a fan on the condensor to kick on with a switch. For A/C dodges are known for not moving enough air across the condensor causing high head pressure and hot air conditions, in extreme situations I've seen the overpressure relief blow! Since the fan install it runs cold in any traffic or temp! After you put the fan in have the A/C checked just incase you lost some freon to blow off!
Old Mar 12, 2013 | 11:33 AM
H.R.D's Avatar
Got any pics of your fan setup dangerours?? I would like to see what you came up with.
Old Mar 13, 2013 | 08:17 AM
Sure I'll get one up tonight!
Old Mar 14, 2013 | 10:35 PM
Esco1's Avatar
There is power at the plug to the fan clutch. I turn the key on and check the plug with a test light and there is good power to one wire and a lower power to another ( the test light bulb does not light up bright). Confused,
Old Aug 22, 2017 | 12:13 AM
Kodanorrid's Avatar
Default 2004 cumins
I have an 04 cummins 440k miles strong motor but not starting on its own I used seafoam a few days ago got it to start for a day or 2 now back to not starting.. I'm lead to believe it's my injectors. I have also had my fan clutch wires cut the fan wires are hanging with no plug but I don't know where the wire harness to the truck is. Does any one know where they run to?? Any help will b r greatly appreciated thanks
Old Aug 24, 2017 | 08:47 AM
CumminsCoalRoller24/7's Avatar
Ive had this issue before- check out this link
http://www.cumminsforum.com/forum/3rd-gen-non-powertrain/351123-fan-clutch-wiring.html#/topics/351123
JoeyMiR
9
Feb 3, 2018 10:05 PM
Daylon
Aug 23, 2015 11:01 AM
ryank 199
May 14, 2015 06:41 PM
jordanokc
Feb 8, 2015 03:59 PM
DSM1988
Jan 25, 2015 07:23 PM
