Diesel dump
Old Mar 8, 2013 | 07:53 PM
Megadad80's Avatar
Default Diesel dump
I'm looking to get the best of both power and mileage. I just replace the motor due to a cracked block. Starting from scratch I just put a 4" exh and cold air intake. This truck needs to pull 10k and hold a load . What do you guys recommend and from where. I don't mind shopping around to get the best stuff. The truck is a 98 auto 4x4.
Sorry guys- first time- truck is a 98 chevy 3500 with 6.5 .
Old Mar 9, 2013 | 02:55 AM
97cummins's Avatar
Old Mar 11, 2013 | 10:53 PM
MontanaTechPetroleum's Avatar
Heath diesel makes a ECM upgrade that is supposed to give a 40hp boost and better mileage while towing. Other than that, buy a holset hx40wII turbo and crank it up some. Don't exceed much more than 15 psi or you might find your engine parts laying on the road somewhere. You can exceed the 15 psi if you put 18:1 compression pistons in there and crank it up to over 25 easy.
Old Mar 12, 2013 | 07:11 AM
Megadad80's Avatar
Thanks- do you think an inter cooler will help any? I've heard it will get me a little more mileage.
Old Mar 12, 2013 | 10:18 AM
They were actually talking about intercoolers on another thread a bit ago. Most members agree that the the only time you really see benefit is when you're making more than about 12 psi, I'd say if you went with the hx40wII turbo, go for the intercooler as well, since it can pull a greater volume of air than the gm-series turbos. If you keep the stock turbo, its probably not worth putting an intercooler on it. If you want to keep the stock turbo, you can make a mechanical wastegate for pretty cheap, but most people end up getting about 2 mpg less, this lets you crank higher boost out the stock turbo.
DIY Turbo Master
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Strictly Diesel
Strictly Diesel
Jun 30, 2015 06:48 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
