my 93 6.5 td needs help me help it
Old Mar 7, 2013 | 09:41 PM
bubbagray62's Avatar
Default my 93 6.5 td needs help me help it
im a 1st timer and clueless to y after changing fuel filter and pump my truck will crank fine n the mornings but 10 mins after driving its like its choking to death what is wrong
Old Mar 7, 2013 | 11:26 PM
detroitdiesel idi's Avatar
Air in the lines most likely . did you bleed them?
Old Mar 7, 2013 | 11:31 PM
how u do that
Old Mar 7, 2013 | 11:35 PM
Theres a bleeder screw on top of filter housing loosen it up n crank engine till fuel comes spraying out. when did you change the filter? and did you use ac delco lift pump its the only one that will work with your ops. it could be your ops switch but most likely air if it didnt happen before you changed the filter
Old Mar 8, 2013 | 05:57 AM
Mayhem's Avatar
The easiest way to bleed the air from the fuel lines is to run a wire from a positive terminal on one of your batteries to the G terminal on the ALDL port under the dash fist open the top of fuel filter housing then close it and open the T valve this way is not as hard on the batteries or the starter
airspeed181
Jan 19, 2015 09:00 PM
Levis95
Jan 11, 2015 01:54 AM
Snoobly
Dec 11, 2014 11:59 AM
bdemutis
Dec 7, 2014 01:36 AM
bdemutis
Nov 28, 2014 08:16 PM
