Part interchanges for 1991 power ram
Old Mar 7, 2013 | 05:16 PM
First Gen Transplant's Avatar
Default Part interchanges for 1991 power ram
What or Who is the definitive source on which parts are interchangeable? eg: frame cross-members, wiring harnesses, complete cab, etc.
I'm thinking of moving my chassis to another shell (like buying a donor half-ton gasser ram) so I want to make sure everything will simply bolt on.
I don't get by this way very often so don't hate me for long delays in responses.
Thanks!
Old Mar 13, 2013 | 02:35 AM
1stgenblowingsmoke's Avatar
They all used the same frames so you should be good. you may have to use the tranny cross member n drille some new holes but otherwise the frames will swap. I'm doing an 85 crewcab conversion everything is bolting in or plugging in.
Old Mar 13, 2013 | 05:04 PM
Default How about the wiring harness on the alternator?
How about the wiring harness on the alternator? I have a line on another first gen that is going for parts and I like to avoid solder repairs when I can.
